Most Fuel Efficient Cruising RPM w/ 300 I6
From my experience, the best range is around 1800 - 2200 RPMs. Of course, your results may vary, but that's where I've found to be a good spot.
My '81 has a 3.00 rear and 31" tires. It used to have the SROD transmission, which had a 0.71 overdrive. At 65, I'd be at 1500 RPMs and 75 I'd be at 1750. It was just too low and the engine had to work harder to turn those big gears over. I found I'd get better gas mileage if I shifted to 3rd (the 1:1 ratio) and cruise at 2150 RPMs at 65mph. Because of this, I swapped out my SROD for an NP435, since I never used the overdrive.
On the other hand, my '84 has practically the same setup, but has 3.55 gears. At 65, it's at 2500 RPMs and at 75, it's at 2900. It's just way too high, and I can tell when I fill the tank.
So yes, there is a good middle ground between too low of RPMs and too high.
Thanks guys, Ill look into it. I was cruising down the highway today and the truck kept dying on me. If I turned the key off, then back on, itd go a little further then start to go out again. A little quick diagnosis says the coil may be out. Once I get that fixed, Im going to take another look at my timing.
Ive always had timing issues on this thing. That seems to have been the problem from the start. The distributor was off time, 180 degrees out, and it wouldnt run. So maybe that is contributing to my high RPM. I have good power to it, though.
Another question. When I go about 60-70 and take certain curves on the bypass, the trucks RPMs will drop off all of a sudden, then the truck will roar back to life, then lose power, then roar again. This goes off and on until the road straightens back out. What may cause this?
"The 300 has very strong torque and I wouldn't exactly call 1600 rpm "lugging".
Well,...maybe.
1) when the engine cannot be accelerated by applying full throttle and/or
2) When the pyrometer and coolant/oil temperatures were rising and oil pressure was less than normal for the revs
Those are the principles for big-truck operation and at what point lugging may occur and down shifting is necessary. The variables are infinite and there is no way one can actually come up with a specific RPM that is definitive for determining 'lugging' or what RPM is best for MPG.
Well,...maybe.
I thought about that, but the engine doesnt even attempt to die when it is sitting still and I turn the wheel, or at slower speeds. Im not disputing you, just clarifying that this ONLY happens at ~65 miles on a certain turn or two. If I can do it safely, tomorrow I will video what it does as I take the turn.
Mostly because it only happens while you're turning. Unless you're turning SO FAST that the gas sloshes to one side of the carb and starves the engine .
Seriously though, that is a strange symptom. I'll try and think of what else would cause that. However, if you're really wanting help, I'd suggest starting a new thread.
Are you having to apply the brakes while taking the "certain curves"? Perhaps the master cylinder has a vacuum leak?
Boy, if it was mine with those symptoms, I'd check fuel pressure.
If you can, get a gauge on it while you make the truck bog down in corners.
Probably it's ok, but if there's junk sloshing around in the tank,
that MIGHT do it.
It also rules it out as a source of problems in general...
hth
t
that MIGHT do it.
hth
t
sounds more like fuel starvation to me. Root cause - who knows? The suggestion about checking fuel pressure is a great one; also how full is the tank when this is happening? Or - had a friend who had crap in his tank and when he floored it, sucked up crap which plugged the pick-up screen - when he backed off it pulled fuel normally. Lots of things can cause this. Could also be something like a bad ground at a point where going around the curve pulls on the ground strap funny or pulls a poorly grounded component loose. Just m $.02.
94shorty
37
10-01-2009 08:54 AM
matt2491
08-08-2008 07:44 AM
