Replacement harness
Some dealers and obsolete suppliers still have some of the accessory harnesses. I struck out trying to find an NOS dash harness for my own project (also a '73 F100) and the frame harness that runs to the rear along the frame rail, but I did find all the other harnesses.
Let me know the specifics of your truck and I'll search for a harness.
On the main harness the biggie is does it have alt and oil press. gauges or idiot lights.
After selling my 79 S.C. along with the 79 f100 and 79 bronco,with plans to quit playing with old trucks,I found this 73 f100. Ha ha , so i guess i'm back in the game. Thanks to both of you, mikeOoOoO and bucks77ford, for the information. ___JIM__
I did the same on my own '73 F100. It took nearly a year (and $175.00) to find one. Mine was for a truck with the gauges.
There are two other accessory harnesses in the engine compartment. One is the harness that connects the ign. coil, oil press. sender and water temp sender to the main harness. The second is the headlight harnesses (2). I did find some of them incase you're interested.
The inst wire harness is D4AZ-14289-R
Green Sales, Cincinnati, OH has 1 (800) 543-4959
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
Greisel Ford, Okarche, OK has 1 (405) 263-7242
The headlight/marker light harness is D3TZ-13076-A You'll need two
Green Sales has 10
Wesley Obsolete Parts, Liberty, KY has 2 (606) 787-5293
JST Automtive, Lebanon, TN has 1 (615) 443-3086
Antique Auto Arlington, Arlington, TX has 1 (817) 275 2381
The first picture shows the alternator harness and the engine inst. harness. The second shows the headlight harness.
Just a note, the inst harness is sort of a semi-universal one The wires are actually longer than the originals. It works fine I just had to coil a small section to take up the slack.
Green Sales has 10
Thanks,very helpful,at least there is some stuff out there if i really need it. I should know a little more after i get things taken apart.
