i am having troubles getting a pto for my F600 with a clark 5 spd. I got one but it goes WAY slow, also side note can i mount one on the t case instead? thanks, any info or part numbers would be soooo appreciated!! thanks
Most pto's have the drive gear, and then 2 more gears that control the output speed. If its a muncie TG unit the parts should be easy to find. Couple hundred bucks tops to get whatever ratio you need. Goes from like 16% to 128% of engine speed.
