Towing an F150 4x4 automatic
Conventional wisdom says it's OK to flat tow an automatic a short distance at low speed. Towing further & faster calls for disconnecting propshaft so as to avoid toasting tranny.
Most states also require any vehicle on the road to be registered, licensed & insured. Even just back wheels on road from car on tow dolly.
When you "transport on a trailer" that's licensed these issues are avoided.
Follow on question here. I picked up an '03 at the crash auction so I need to have the title inspection done at state police. It's too big to fit on a U-Haul trailer so I am thinking about using a tow dolly. I don't really feel like doing the driveshaft disconnect so I have another idea. I only need to go 20 miles and I've read that the trans damage comes from the engine not running and therefore the trans fluid pump won't run. What if I left it running for the trip? Just idle and neutral. I don't need to speed, all back roads so 45mph max.
What if....before leaving the auction site there is inspection for safe travel? kinda doubt that leaving it run in neutral on a tow dolly is going to go unnoticed?
Better to borrow/rent a trailer or have it towed/hauled....even though you have a relatively short distance. Or just drop the drive shaft.
Mitchapalooza85
22
12-10-2018 08:31 AM
