Rear suspension
Old 04-04-2012, 01:17 PM
baumst's Avatar
baumst
baumst is offline
Rear suspension
Today I learned that my coil springs over the leaves in my 1960 are not a stock item.
I am getting beat down like Rocky Balboa when I drive this thing down the road. I thought... heh, old truck.
How soft is the rear on a stock suspension if I pull those out and leave the leaf springs and shocks?
Old 04-05-2012, 01:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
How many leafs are in the rear spring pack, seven or nine? If less, someone either removed leafs from the pack or installed 1965/67 F100 5 or 6 leaf rear springs (a bolt on replacement).
Coilovers were available at the parts counter. If the shocks are marked Rotunda (as original), Auto-Lite or Motorcraft (service part replacements), they are genuine Ford parts.
Coilovers (usually Monroe's) were also available from autoparts stores, spring and front end shops, RV dealers.
Old 04-05-2012, 08:45 AM
baumst's Avatar
baumst
baumst is offline
9 leafs, a set of coils over the axle and shocks in the normal 1960 spot
Old 04-05-2012, 12:30 PM
2losteve's Avatar
2losteve
2losteve is offline
I'd pull them and see how it rides. How do you intend to use your truck?
JayzDaddy
13
04-11-2014 04:28 PM
undertakerman
07-01-2010 04:59 PM
jeff8362000
11-19-2009 12:44 AM
Psycho Sasquatch
04-02-2007 08:43 AM
Rogue2KC
Bronco II
08-26-2002 12:01 PM
Quick Reply: Rear suspension
