6.2L V8 Discuss the 6.2L V8
7.5 Quarts in 6.2!!
Old 05-06-2016, 04:16 PM
Tawn's Avatar
Tawn
Tawn is offline
7.5 Quarts in 6.2!!
After the dealership jerked me around and "forgot" to change the oil in my truck even though I had an appointment, the keys were in their night drop box and the truck was parked about 6' from the service department door, I took my truck to a reputable independent shop for an oil and filter change - I even specified to use a Motorcraft filter.
After I got home this afternoon, I noticed the receipt had 7.5 quarts Kendall Full Synthetic on it - called them back and sure enough, they put 7.5 quarts in it. Their thought was 7 quarts is called for for the engine and the filter holds about a pint. I popped the hood and sure enough, the oil level on the dipstick is slightly above the "MAX" hole.
It is raining sideways here and the truck is too tall to fit in my garage, so draining the 1/2 quart out myself is not an option - at least today.
I have two charters Saturday and two Sunday which means I need the truck all weekend and will not have time to take care of it until at least Monday (after I have driven it 75+ miles)
My question to the collective is.....IS THIS EVEN WORTH WORRYING ABOUT? I mean it's only an extra pint in a fairly large V-8. I know the owners manual states that if the dipstick reads over the MAX line the excess should be drained or serious engine damage could occur but my gut tells me I am being **** retentive and it's not a big deal.
As far as changing my own oil and avoiding problems like this..... I only wish I had the time. A full-time job + over time and I run a charter boat. I sometimes don't know whether I am coming or going.
Old 05-06-2016, 04:23 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
If the oil level is high enough to be in the crank, the constant "stirring/whipping" of the oil will cause it to foam. This is very bad. But will an extra half quart put it at this point, idk, but I doubt it.
Old 05-06-2016, 04:52 PM
Strokin-A-2010's Avatar
Strokin-A-2010
Strokin-A-2010 is offline
It's 7 qts. Don't understand why people think it holds more.
Old 05-06-2016, 05:07 PM
Tawn's Avatar
Tawn
Tawn is offline
That is what I am thinking, a pint shouldn't raise it enough to be a serious issue but I'm not sure either. Don't these engines have a windage tray under the crank?
Me either - next time I will be more specific with them: Use a Motorcraft filter and use ONLY 7 quarts and not a teaspoon more.
Old 05-06-2016, 07:46 PM
R Guest's Avatar
R Guest
R Guest is offline
I just looked at Fords website and it said its ok to fill to the max mark on the dipstick. In my 2016 F350 7.5 Qts puts it right at the top hole in the dipstick where the owners manual says is the max fill mark. I agree it also says the engine says it takes 7 qts. It states anywhere between the max and min marks on the dipstick if in the operating range. I have and always fill mine to the max. You are fine in my opinion.
Old 05-06-2016, 09:22 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Originally Posted by Tawn
That is what I am thinking, a pint shouldn't raise it enough to be a serious issue but I'm not sure either. Don't these engines have a windage tray under the crank?Me either - next time I will be more specific with them: Use a Motorcraft filter and use ONLY 7 quarts and not a teaspoon more.
I haven't done much research on the internals of these 6.2's, but it would not surprise me if there is a windage trey, a lot of modern motors are using them. But the windage trey would not keep the oil from foaming if the oil level is above it. Again I highly doubt you have anything to worry about.
Old 05-06-2016, 11:05 PM
dkf's Avatar
dkf
dkf is offline
I highly doubt it would hurt anything, just may possibly cause a little extra drag on the crank. When you get time you could drain a little out if you want. Though the engine will likely use a little oil over the OCI.
As far as I know Ford factors in the filter when they list the 7 quart specification. I have never been able to get a pint of oil in a Fl-820s filter either, it doesn't hold much.
Old 05-07-2016, 06:09 AM
don123's Avatar
don123
don123 is offline
probably not going to hurt the motor but it would bug me and I would drain that 1/2 a quart.
Old 05-08-2016, 08:52 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
I do my own oil changes...
to the MAX mark on my 6.2L is 7.5 quarts.... as I buy oil by the 5 quart jug.. so I buy 2 jugs.. and save the remainder for the next time. or for the wife's car, motorcycle, or whatever OTHER engine needs oil. or a oil change.
as I use synthetic oil. and with the limited miles per year (5,000 miles).. most get an oil change once a year.
Old 05-09-2016, 06:32 PM
Tawn's Avatar
Tawn
Tawn is offline
Thanks for the feedback - I'm not going to sweat it but next time I will be very specific when I drop it off.
Old 06-01-2016, 10:22 PM
Powerdude's Avatar
Powerdude
Powerdude is offline
I would not worry about it at all.
It's always a good idea to pre-fill the filter, even if it's not all the way, so that no air pockets get created.
Old 06-12-2016, 07:51 PM
Powerdude's Avatar
Powerdude
My owner's manual says 7 qts
I must say, lots of other cars that I've had, I always put in what the owner's manual said, but most of them were slightly below the dipstick mark after driving them for a little bit. I'm sure there is some wiggle room in the system (probably 200 mls or a cupful-ish) in most cars.
I always check after an oil change and make sure the level is full. Oil is cheaper than metal parts.
Old 06-15-2016, 11:55 PM
buzam's Avatar
buzam
buzam is offline
Just did my oil, 7 quarts took me to just past the mid way point on the hash marks.
Old 06-16-2016, 06:45 PM
dtherrien's Avatar
dtherrien
dtherrien is offline
you can safely fill it to the top of the hash marks. 7.5 qts is max. The half qt is the filter. If you fill your filter prior to installing it...theres still zero oil in the pan.
Old 07-04-2016, 06:30 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
Typical submariner
I would think you are GTG
Quick Reply: 7.5 Quarts in 6.2!!
