How to Identify Dealer Air vs Factory Air?
AC from the factory though has the heater core under the dash in the cab, and is really easy to access.
I don't know about 87 to 91, but I think that's how it is 80 to 86. We'll know for sure in a bit.
The 87 Bronco 351W is a throwback. Even though it is considered a "bricknose" it still has the carb and DSII ignition. It has the genII alt and the same steering column. It isnt much different if at all from the 80-86. The 87 has a steel battery tray with a clamp where the 80-86 had the recessed part of the fender for the battery to sit on. It also has a steel mounting plate that bolts to the inside of the fender for the degas bottle and wiper reservoir to clip onto instead of being directly clipped to the fender.
My heater core is inside the dash. All you see from under the hood is 2 -5/8" nipples protruding through the firewall.
As I understand it, if you have air conditioning from the dealer, the heater box will still be under the hood like on non-AC models. It's just an add on, more or less.
At least with 80-86....
If factory AC, the lines from the compressor will run to the evaporator/dryer/whatever-crap which is all located on the engine side of the firewall and in the same box that contains the heater core.
If dealer-added AC, the lines from the compressor will run through the firewall to dealer-added AC stuff under the dash, keeping the factory-supplied heater box on the engine side of the firewall.
There will be some changes to the HVAC controls, too, although I have no idea what they are for 1987.
my 82 had dealer installed AC. Was a complete stand-alone package mounted up under and behind the glove box. Had it's own blower, evaporator, ducting, wiring and resistors.
On the controls there is a switch that is activated when you slide it to AC. This switch not only operated the clutch on the compressor but operated a relay that put power over to that blower motor from the heater blower.
Again...this was on an 82 f100...not sure on your Bronco
I have dash vents and the AC lines run on the outside/engine side of the firewall. The accumulator dryer is outside and there is a big black plastic box outside as well . The blower motor is outside and it has the resistors out there too. Once you pull the blower motor you can see where the evap coil is within the black plastic box that is outside.
For 80-86, what they do is cut smaller holes on the pass side of the front of the dash bezel thing. With factory AC there's a vent on each end, the embossed/raised area fits between them.
Without AC, that raised/embossed area extends the full width of the passenger side.
Dealer-added AC they cut holes in that embossed area and install smaller vents.
Also....
The driver's side - factory AC has vents on both sides of the gauge cluster... dealer-added AC cuts holes and installs identical-looking vents, but they're connected with dryer-vent-hose-type of ducting, not the solid plastic ducting the factory AC comes with.
One of these days maybe I'll come up with pictures. I have pix somewhere of one of the factory installations and what it does to the HVAC controls but I couldn't find 'em, I may have deleted 'em....
Oh, sure it does, so long as it looks like any installation I've seen.
Also....
Also....
Guess I shoud have taken pictures of it all as I disassembled it all. None of it was functioning so I just tore it all out and threw it all away.
One other thing to help ID between the 2. I think on the factory air, all of your dampers to control where where the air is going are all vacuum servo controled aren't they?
On my dealer air...everything is cables. Cable going to the temperature control damper in the engine compartment as well as the damper controlling defrost/floor.
My control also only has 3 positions AC/Defrost/Heater. When you take to to "AC" it activates a switch that switches power to the dealer AC blower away from the Heater Blower.
