86 2.9l Bronco II "bucking and jerking"/ Desperation!! - Page 2 - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 02-14-2018, 10:24 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Any 86, 87 or 88 Ranger/Bronco II 2.9 5 speed computer should work.
Old 02-15-2018, 03:56 PM
killidge killidge is offline
killidge is starting off with a positive reputation.
Right on, thank you! Got one coming from Rockauto...
Old 02-17-2018, 05:02 PM
Hi Lead Head, since you replied to my last post I will see if you can shed some light on my 86 B2 problem. She starts fine all the time. After warmed up and driving for about 5 miles or so I stop at a red light and the idle goes really low almost to barely running. I can hold the pedal to the floor for about 5 to 10 seconds before she picks up the rev. While holding pedal down she is sputtering. If this happens while driving B2 would sputter and buck then I would floor gas pedal for same amount of time roughly then she would take off. Bad scenario if under a red light or something. Things checked/replaced: fuel pressure at 32-36 psi, O2, MAP, EGR, PCV, ECM, TPS, radiator replace and flush out, plugs wires and coil, distributor cap and rotor replaced. Throttle body cleaned (sea foam spray), bad vacuum lines replaced and checked for leaks at this time. If anyone can shed some light on this issue feel free to pass on any knowledge you may have. Thanks
Old 02-17-2018, 07:18 PM
Probably the computer
Steering jerks left, then warning light comes on! Royson12 2015+ F150 30 04-26-2016 11:13 AM
1999 F-150 5.4 Idle / Running Rough - Questions upslash 1997 - 2003 F150 3 01-18-2016 01:58 PM
86 Ranger STX 2.9L auto hiccup and jerking mike205 Ranger & B-Series 17 01-14-2016 05:52 PM
Cylinder 2 & 4 Misfires + No Air in Vents jakeupowens 3.8 & 4.2L V6 1 04-16-2014 09:13 PM
Need help with water in the fuse panel. Kim's Hipster 1999 to 2016 Super Duty 14 03-23-2011 04:46 PM
Tags
1986, 29, 4cyl, 87, bronco, correct, ecu, ford, fuel, ii, oxy, pump, ranger, sensor, surging, vlv29
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
