stock 2011 f250, largest tire I can run???
Old 04-01-2012, 05:50 PM
bobsplus's Avatar
bobsplus
bobsplus is offline
I'm looking at the nitto terrra grappler lt295/60/20 dia. 34.45 width 12.36 weight 3750lbs. will they fit stock 4x4 shortbed truck????
<TABLE class=tireSizeSpec><TBODY><TR class=row5f><TD>LT295/60R20 </TD><TD>201-140</TD><TD>16.6</TD><TD>34.45</TD><TD>12.36</TD><TD>8.0-(8.5)-10.0</TD><TD> 3750
80
</TD></TR></TBODY></TABLE>
Old 04-02-2012, 06:24 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
315/60/20 will fit but rub the front control arm slightly at full turn.
We should have a sticky or something in the tech folder that summarizes this stuff.
315/60/20 fits an F350 SRW with a front level kit but I don't think the level kit really matters. I just have stock tire size on mine.
Old 04-02-2012, 08:36 AM
darren32's Avatar
darren32
darren32 is offline
325/60R20's (35.6" x 13") will fit (on the stock rims, stock offset) but rub quite a bit on the front control arm at full lock.
You should not have any problems.
Old 04-02-2012, 10:25 AM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
Is this with the leveling kit/lift that you are running?
Old 04-02-2012, 10:54 AM
darren32's Avatar
darren32
darren32 is offline
I now have a 4.5" lift up front. But I had those same tires on the stock rims with stock suspension and that is when the rubbing is from. They do not rub anywhere at all now because I went from the stock -40mm offset rims to +12mm offset rims.
Note: you CANNOT go to +12mm offset rims with 325/60R20 tires on the stock suspension! The tires hit the sheet metal at the back of the wheel and the bumper bracket at the front. You can't turn at all (trust me on this one)
Old 04-02-2012, 11:01 AM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
Any pictures of these tires on the stock wheels with stock suspension? I'm wanting to go with the 325/60/20 Duratracks when I get around to doing a leveling kit (waiting for my current tires to wear down).
Old 04-02-2012, 11:05 AM
darren32's Avatar
darren32
darren32 is offline
I actually did make the -12mm offset wheels and 325/60R20's work on the 100% stock suspension. But not everyone is a fan of taking a grinder and BFH to their new truck like I am. Had to cut the bumper bracket off in the front and bend the heck out of the sheet metal in the back (I didn't care because I knew bushwackers were going on and would cover it up).
Here is what it looked like.....
Old 04-02-2012, 11:11 AM
darren32's Avatar
darren32
darren32 is offline
I will check at home tonight and let you know. Not off hand, I only had the tires on the stock rims for about 4 weeks.
Thanks
Old 08-27-2012, 01:06 AM
savage chris's Avatar
savage chris
savage chris is offline
Would you ba able to fit the 35.6 with a wheel spacer with no rubbing
Old 08-27-2012, 10:33 AM
cford716's Avatar
cford716
cford716 is offline
<table class="tireSizeSpec"><tbody><tr class="row5f"><td>LT295/60R20 </td><td>201-140</td><td>16.6</td><td>34.45</td><td>12.36</td><td>8.0-(8.5)-10.0</td><td> 3750
80
</td></tr></tbody></table>
I have 295/70/18 Terra Grapplers which are almost the exact height and width and have no problems.
Old 06-05-2017, 05:23 PM
MichaelAllor's Avatar
MichaelAllor
MichaelAllor is offline
I currently have a 2013 Ford F-250 XLT Superduty Extended Cab Gas, and was
wondering if anyone new the biggest size tire i can fit on it. Im thinking a 285/65R20 Nitto Terra Grappler G2 or possibly trying to fit a 295/65R20 Terra Grappler G2 or the Ridge Grappler. Any Ideas if a 295/65R20 will fit stock with no lift or level kit?
Old 06-06-2017, 08:23 AM
RobRoy32's Avatar
RobRoy32
RobRoy32 is offline
I have a bone stock 2011 truck with stock rims, currently running Toyo Open Country AT II that are 295/65R20. No rub. Really liked these tires for the first 2 years/40k miles, but even at 40k miles, and decent amount of tread left, the rubber compound has become very hard. Wet traction is pretty poor at this point. I would say I have over 30% tread left, but am looking a replacing for wet traction alone.
Old 06-06-2017, 08:34 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Received 2,176 Likes on 680 Posts
My son in laws F-250 with 285x65x20 BFG KO2's at stock height...probably 35K miles on them in 2 yrs easily. (34.5x12)
Old 06-06-2017, 10:47 AM
FGallagher's Avatar
FGallagher
FGallagher is offline
I ran 35x12.5" for years and never had a problem.
Old 06-06-2017, 11:35 AM
MichaelAllor
Was That on a stock truck? or did you add a level kit?
Quick Reply: stock 2011 f250, largest tire I can run???
