3G Swap: Should I think about doing one?
#62
OK so heres where I am at and my last couple of questions.
1. Got my new alternator off a 93 Taurus 3.8
2. Had it tested at the local O'Reilly
3. Got some #1 welding cable, lugs, and Red heat shrink from work
4. Reclocked the alternator and hopefully without damaging it. (need a thread with pictures for future users couldn't find anything on ANY forum)
Now for questions
1. The donor alternator has a right angle insulator that comes off the back of the alternator. It would be a cleaner install if this was straight and I can do it without the insulator too just hoping someone knows where to get one.
2. The rubber boot in the kit in one of the first posts, does anyone know where I can get just that boot?
3. Just started looking but the local O'Reilly only had the fuse and no holder and the nearest NAPA is some distance, open to suggestions.
4. I being a lame reared knuckleheaded dipstick forgot to get the plugs from the donor car. My current 2G has 2 3 wire plugs and the 3G has a 3 wire and a 1 wire. Anyone know where I can get the grey 1 wire without a return trip to the wrecking yard? Going by the dealership later today their electrical guy like me since he bailed me out on my cooker lights and I smoked him a brisket.
Now for questions
#63
Now for questions
You can see it here;
2) You might try an auto electric rebuilder or a body shop.
....Maybe a marine supply (chandlery)
The only places I know of sell them in lots of 25, 50, 100.
3)I have seen the Bussmann holder and MegaFuses at my local Advance Auto.
4)The 1 wire is just the white/black wire looped from the three wire plug you already have.
Almost any crimp on insulated spade plug will do in a pinch.
#64
Found a fuse holder at O'Reillies they apparently don't know how to look up their own inventories (God I miss the days when auto parts stores actually had people that worked on cars at the counters). Going to use an insulated sta-kon for the missing part if I can't get one quickly. Plan on doing this tonight when I get home from work.
Oh and yeah I have the 90 degree thing off but in some of ya'lls posts they had alternators with a straight insulator not necessary but I am **** on things looking good. Thank You all for the help.
#65
@ Intimnasc
You might have the O'Reilly store order a holder, they usually get regular deliveries. Or order it on line from NAPA. I don't know how big your town is, but you could check with a big truck shop, farm equipment shop, or even a stereo shop ... just remember a "MEGA FUSE" only fits in a " MEGA FUSE" holder!!! IMHO the #1 welder cable is overkill but if you got it use it. I used 2ga. on mine. You might think about going back to where you got the alt and getting the wiring. If you are unsure about your re-clocking job have it checked again it's free !!!
#66
#67
One thing I would like to add that I realized I didn't mentio. Is that the larger lower bolt for the alternator did not fit in my new 3G when I went to put it in. I took a drill bit that just fit in from the back of the case on the lower hole and drilled it out. Just I case anyone has the same issue. Completely different note: anyone want an old 2g alternator? lol
#68
#70
Update: No issues, everything working well. Maybe fog lights in the future?
Just took some more pictures of the harness incase anyone is confused. Next run to pick-n-pull I might grab another plug harness and show how that is made. But for now these might help.
Run the newly made harness's green wire to this plug:
I cut the one end off the old alternator wiring and attatched it to the new harness.
And here is a better shot of how the harness goes onto the alternator:
#71
Got it done last night with some minor issues I will fix this week. The lug I used had a 3/8 hole at the alternator so I'll go by the supply house this week and get one. I am goiong to move the vacuum canister and that smog can on the fender well to locate the fuse more neatly next to my sound systerm fuse. TRhe whole process would be much easier sober, may try that route in the future.
#72
#73
Evan_P, mine has done the "squeak" from day #1. What I read on here was that the cure is going to an 8 rib belt and pulley system, I understand it is a $$$ fix. my tension pulley is indicating mid-range and the belt is new. When I do replace the belt, I will go with a Gatorback belt ... otherwise enjoy the reminder that you upgraded your alt.
Dave
Dave
#74
