boss9f100 Projects page
Old 08-15-2012, 06:31 PM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
Originally Posted by Grubbworm
I think you are doing an awesome job. That is something that I've always wanted; an older car/truck with all the up to date bells and whistles underneath. Are you going to leave the body mostly stock looking?
Originally Posted by Osiyo59
Now, I know I read more on this post yesterday.
Originally Posted by Krewat
Very nice... the pictures of the Ecoboost are priceless in and of themselves
Originally Posted by Frankinstine
Keep up the good work!!! Just watching you work on this makes me excited to see this slick run like a top.
Originally Posted by tojoski
Just stumbled upon this. What an awesome project.. Will definitely be subscribing here.
Thanks All!
Yesterday evening I was able to start fitting the cab to chassis. By far the most difficult portion of this project. Brain is getting old and does not think so well anymore but still gonna make it all work.
What makes it even more difficult is it far too hot outside where the hoist is so it needs to be done inside where its a bit cooler & that for most part working by myself. Waiting for a friend to drop in to position the cab.
Because the "donor" veh was a 154" wheelbase and the new chassis is only 126" I was a bit worried about the exhaust system. I found that if I removed the factory resonator and just welded the resonator pipes together it was proper length to fit in stock ford exhaust hangar brackets! Original tail pipe was damaged when it was hit so will need to fab one up.
  #167
Old 08-15-2012, 07:21 PM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
Sweet build!!
  #168
Old 08-19-2012, 12:50 PM
Boss9F100's Avatar
Boss9F100
A couple friends stopped by yesterday to help me with the cab and cab floor fit.
Made some good progress!
Now the floor is fitted to cab,
  #169
Old 08-19-2012, 04:52 PM
Osiyo59's Avatar
Osiyo59
Osiyo59 is offline
Now this is where it is going to get interesting. As a bodyman I love to see people go mental-creative on these type of projects. Keep at it Randy and keep the pics a commin'
  #170
Old 08-19-2012, 06:56 PM
Boss9F100's Avatar
Boss9F100
Turns out the 2011-12 firewall is within 1/8" or less of the 1966 Firwall width! Simply amazing is the spot welds even align where they come together . ..
Body cab mounts on the way. Once they show I can get rear of cab mounted.
I moved the cab forward on frame as much as possible to still have an ok look on front wheel openings. Cab is as low on chassis as I can put it and still be able to have engine clear hood and cowl area. A lot of compromises to make it all work.
The dash will be a little challenge also. Once that is done and floor welded in could probably take it for a spin, LOL of course the '66 front end is probably a FOOT shorter than the 2011-12 so will need some fender stretchers to get it to fit. Now that the cab is lowered on the frame, core support/ radiator also nip and tuck. Intercooler will be toughest part as if mounted in 2011 position it would be 8" or so in front of bumper . . .
  #171
Old 09-01-2012, 07:17 PM
Osiyo59's Avatar
Osiyo59
Osiyo59 is offline
BUMP Any more progress on this Randy? Or maybe you are getting back to the "R" code F100
  #172
Old 09-01-2012, 07:50 PM
1_ton_bronco
Bump for a sweet build
  #173
Old 09-02-2012, 11:50 AM
Nabors's Avatar
Nabors
Nabors is offline
BUMP! I'm glad I stumbled upon this! Looks like a great build! Fantastic work so far!
  #174
Old 09-02-2012, 09:35 PM
Boss9F100's Avatar
Boss9F100
I have not been feeling so well for past couple months. About a month ago started to feel warm and did not realize it was a low level fever. (have not had a fever in 40yrs) This past Monday was feeling quite warm again so took my temp
105.6, even with tylenol etc the temp would hover around 101-102. So Tuesday went to the local urgent care, they immediately sent me to ER
I then spent a few days in hospital. Turns out I had a bad case of Pneumonia
with a large portion of my right lung infected.
Doc says it could be a month or so before I start doing better but should feel some improvement after a week. Fever just will not go away. Really hot as my normal body temp is 97.x not the normal 98.6.
If this keeps up I may end up back in hospital as having difficulty eating or even having much for fluids. The IV's given seemed to do a much better job.
Sleeping nearly around the clock now...
I did make a little progress even tho I was feeling so crappy but think it will be a while before I can get back on the project.
  #175
Old 09-02-2012, 09:53 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
Your health is more important than any build. I hope you get to feeling better soon.
  #176
Old 09-02-2012, 10:50 PM
1_ton_bronco
I agree. Health is top priority. Feel better and get well!!
  #177
Old 09-03-2012, 11:46 AM
Osiyo59's Avatar
Osiyo59
Osiyo59 is offline
Yes, Take care of your health first Randy. When you're better you can get back to working on the trucks and teaching us a few more things.
  #178
Old 09-03-2012, 12:02 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Hope you get feeling better Randy. Plenty of time for projects your health does come first. You can take a long time away from a project and you know what when you are ready its always there just where you left it.
  #179
Old 09-03-2012, 12:42 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
DPDISXR4Ti is offline
I've ignored all my e-mail update notices to this thread until today. Not the update I wanted to see, but that can wait.
Take care of your health first Randy. Everything else can wait.
  #180
Old 09-03-2012, 02:40 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
Hope you get better soon so you can get back to your magic! Take care of yourself first though!
Quick Reply: boss9f100 Projects page
