A/C quit - what to do to keep things from getting worse
I turned on the A/C in my 2001 F150 for the first time this season, on the first day to exceed 80 degrees, & found no cold air coming through the vents. The F150 is not my main vehicle & I intend to use it for hauling stuff, and not for pouring much more money into than I absolutely have to. I can do without A/C indefinitely.
I have had A/C compressors seize up on previous vehicles & don't want this to happen on my F150.
Is there anything I can do (cheap) to prevent things from getting worse?
I don't know if the F150 compressor is a problem. I kind of suspect the refrigerant has leaked out, but I'm not interested in paying anything to figure out the exact cause, since I can do without the A/C altogether.
Now & then I do have to turn on the Defrost setting to blow condensation off the windows, I know that switch will activate the compressor in any weather.
I was thinking of pulling the electric plug to the compressor to prevent it from being engaged by the Defrost setting.
Are there likely to be any bad results from doing that?
If it's low on refrigerant, the low pressure switch will prevent the compressor from coming on, in A/C mode and defrost.
I have had many vehicles with dead A/C systems, and had no problems since like was said before, it does nothing but sit there and spin with the clutch disengaged. The clutch can eventually wear out, but like wise the waterpump, power steering pump, etc. can wear out also.
Spend $15 on a can of r134a and put that in and it might start working again.
I guess I got traumatized by my bad experience with 2 successive Chrysler A/C compressors, and want to avoid any further trouble (or expense). I know I can put in an idler pulley but don't see the point in doing that if the compressor can be left in a nonrunning state.
Can there be any harm from simply disconnecting the electric wires to the compressor?
jimbo beam
12-12-2009 05:17 AM
