1995 F150 351W Build Thread - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 12-19-2015, 10:28 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Originally Posted by TexasGuy001 View Post
... I see Duplicolor has New Ford Gray engine paint. Isn't that a bit brighter of a color than what was originally used?
That's whats on mine. You can see plenty old/new comparisons side by side in my thread.
  #182
Old 12-19-2015, 07:18 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
I have the same color on my 88 and really it darkens up quite a bit after a few runs so it really comes out close to original. I have a pic in my build thread of it painted but not sure if I ever got a pic of it after running it a few times and right now it is to dirty to get a picture.
Trav
  #183
Old 03-25-2016, 12:10 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I've finally gotten around to opening up the 5.8.
  #184
Old 08-03-2016, 03:13 AM
GoinBoarding
GoinBoarding is online now
GoinBoarding has a good reputation on FTE.GoinBoarding has a good reputation on FTE.
Any updates? This has been a useful thread, thanks for sharing.
  #185
Old 05-17-2017, 10:31 PM
TexasGuy001
This really has not been moving forward much lately. That was due to several factors, including taking classes again. I have actually started, stopped, and restarted this project once due to changing trucks and selling and re-purchasing another 5.8. Recently, I have started working on this again.
I have a question about the Comp 35-512-8 and GT40 heads. I am considering a set of remanufactured GT40 heads. Will the valve springs need to be upgraded in regards to the cam being used?
  #186
Old 05-17-2017, 10:42 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.
I just went through this on another thread. The question is "will the springs that come with my reman'd gt40 heads be adequate for the cam I want?", and the responsible answer is "not without testing the springs as per the specs provided with the cam card". Don't assume, who knows what you're getting with the heads. Are they adequate? Maybe. Can any of us tell you? Nope.
Test them, or just buy the recommended springs off the rip.
  #187
Old 05-17-2017, 11:58 PM
TexasGuy001
Well, I did find this info from the manufacturer. It says in the notes that stock springs need to be upgraded. I also noticed that it says that it is compatible with 5.0, but not with 5.8.
35-512-8 - Xtreme Energy? Computer Controlled Hydraulic Roller Camshafts (For 1992-02 Magnum Engines WITH 1.6:1 ROCKERS)
  #188
Old 05-18-2017, 08:14 AM
Scndsin's Avatar
Scndsin
Well that's my cam & I'm using my upgraded trick flow springs with it and 1.7 rockers.
I did have a long discussion with Comp tech support that yes, it was a 5.0 cam & it would play nice in my 94-5.8 SD 2wd E4 & 3.08s' before I pulled the order trigger with Summit.
  #189
Old 05-18-2017, 09:48 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Yes, any cam that works for a 5.0 will undoubtedly work with a 5.8. In fact, with added displacement, there would be cams that worked for the 5.8 that wouldn't work on a 5.0. With added displacement, you can run "larger" cams and still keep the SD system happy.
  #190
Old 06-14-2018, 05:36 PM
Mista_J_92
Mista_J_92 is offline
Mista_J_92 is starting off with a positive reputation.
1995 trans
Quick question. Do I have to replace my 95 E40D with another 95 E40D? Or is there other options. Sizes/years ECT.
  #191
Old 06-28-2018, 12:23 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
might want to start a new thread, but that method is always safest. Usually if the electronics plug in, it is compatible.
Do you mean if you swap in a 351? Or just replacing the trans? We kinda need a little more info on what you're doing.
  #192
Old 06-28-2018, 02:36 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Also, what oil should I use?
cookster351
120
10-14-2018 06:18 AM
Eric1976mi
10-01-2017 08:55 PM
patrickj20
07-31-2017 10:07 PM
Lagniappe
10-18-2016 11:33 PM
eduhat
19
03-25-2016 08:57 AM
Quick Reply: 1995 F150 351W Build Thread
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
