1966 F150 build
#48
#49
#52
#53
#54
Ok, the day went as planned. We got our errands run and I got the '66 around front and only screwed up traffic for a couple minutes. I also cleaned out the bed to get it ready to pull off tomorrow.
Hey Bob, any chance I could get Ka'Bluey's old tail gate when you're done with it? This one is rough.
#55
#56
Thanks Rich, take your time. Whenever you wake up on Tuesday or Wednesday would be fine.
RC, this chassis is complicated. The bed is coming off and being set aside. Then all I'm using from the rear suspension is the side frame rails. I'm using the Bronco crossmembers and rear suspension. This way I can mount the Bronco gas tank under the bed and use the rear axle's 3" springs and not have to change the spring perches on the rear.
The Bronco frame has a real bad 4" kick up in the frame behind the front seats. If I were just to stretch the frame, the body would sit flush in the back, but be 4" off the frame in the front. When I'm done, I want this truck to look like it was made this way. I'm taking extra time to make sure everything looks like it should on the chassis.
#57
Must be a GOOD friend to do all this for, when you can find a old 4x4 around every now and again.
FOUR WHEEL DRIVE FORD 1966
!!CLASSIC!! FORD 1966 TRUCK
Same truck was 3000 now 2100....
Antique 65 ford f350 4X4
#60
