Big problem!
Old Mar 23, 2012 | 09:26 PM
ericford1984's Avatar
ericford1984
Exclamation Big problem!
I was driving the truck 1984 f250 4.9 and the throwout bearing I guess it's called went.. The truck wants to keep
Going even though I have the clutch pedal
In and it squeals and it won't shift out of gear unless it's off and then I drove it home and I had to start it in gear an drive it home like that..Is it a throwout bearing?!
Old Mar 23, 2012 | 10:12 PM
85e150's Avatar
85e150
Inspect the clutch pedal, linkage, hydraulics if you have them. Start at the pad on the pedal, and work down to bell housing.
The squeal tells me it has to come apart anyway, but you need to make sure the clutch linkage is working. Trucks of that year have firewall flex issues, compounded by rust now after all these years. You must make sure your linkage/hydraulics aren't compromised by worn parts or flexing.
Having said all that, again, because of the squeal, I think this has to come apart.
ALL NEW components are in order, and if the rest of the linkage/hydraulics are good, you'll be back in business.
Old Mar 25, 2012 | 09:50 PM
Karjalanwarrior's Avatar
Karjalanwarrior
Sounds like carrier bearing failure. Also check plastick pushings in shaft holding clutch and brake pedals. Had that kind problem with one of my older fords.
FuglyF100
Feb 26, 2021 03:38 PM
palsims
Sep 20, 2015 09:37 AM
cjcathey2002
Apr 12, 2008 11:46 PM
Morris98
Dec 2, 2007 07:49 PM
DAV1972
Aug 14, 2007 11:11 PM
