Cold Air Intake on a 460?
I'm about to lift my truck, and I know I'm going to lose some power. Seeing as going from 9 mpg to 7 doesn't sound attractive, I'm looking to get some power back. I found a K&N Filter (1992 Ford F-250 S&B Cold Air Intake - Best Price & 290+ Reviews on S&B CAI Carb Approved Air Intake Systems & Kits) that looks like it should do the trick. Any experience with putting a cold air intake on a 460, or any opinions? Also, I was thinking of a more free-flowing exhaust. I looked around and found this Flowmaster Kit (Flowmaster 17198 Flowmaster Force II Tuned Cat Back Exhaust Systems - Trucks) and have heard good things about it. Any opinions on that? Also, the family's lucky enough to have money not be an issue, so I'm not worried or wondering about price to much.
Anything helps.
Jake
Anything helps.
Jake
Anything helps.
Jake
Anything helps.
Jake
(Arlen) SPICER wrote,
“Now that I am not doing the tests and my objectivity is not necessary, let me explain my motivation. The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature. Gentlemen and Ladies, Marketing and the lure of profit is VERY POWERFUL!
Mufflers- a stright through design is the best...no matter who makes it.
Given the age...check the cat...it might be partially clogged, O2 sensor tired/lazy....likely culprits.
Lots of performance/mileage info on the 460 sub forum.
I just cut my air horns off. Here's what it looks like before, 2nd picture is of how much it's restricted....
Didn't really notice a power increase, but it was free.
My next step will be the timing bump, another cheap mod I learned about on this forum & after that I'm gonna get serious with a set of headers, free flow catalytic converters & mufflers, which, from what I've read will really wake my truck up.
It's easy to tell where to cut once you get apart.
See the two lines between the air box & the two horns in the top photo?
That's where I cut, just so you can still clamp on the intake hoses & the holes are at the same diameter going in & out.
That's just a couple of hoses & some sort of filter on the bottom.
I do have a picture of it from upside down that shows it better.....
Does soundmuch better with 'em cut.
Bruno-the-Dominator
09-22-2003 05:07 PM
