Is a 289 motor
Hi Everyone : I took the motor apart an put the cam back in right, friend who put the cam in is a chevy guy lol ( do I need to say any more ) after I put the cam in right I did a compression check an I am getting 145 psi. in the motor so I put back together an it stated
an ran good I am pretty lucky . Thank you for all your help . Rick
U use a degree wheel to set it 2 proper advance? I'm more familiar w/the I6 & havin IT degreed to the 1st key @ 4* for a 265/265 cam...
Why use a 289? I hear there's no bottom end. Don't know why the 302 & 5 oh would give a better hole shot w/only 13 more cubic inches. May B their 'stroked' 289s?
180* out will not hurt the engine. Think about it, during normal operation the cam will become "180* out" every other crankshaft rotation. The only thing you did was shift the firing sequence of the engine over full crank rotation.
Turning the distributor 180*, or moving the plug wires 180* would have made the engine start right up and run fine.
No I looked at the cam gear an there were 3 hole one had a A, the other had a R, an a O I took the rocker arms off an put the right piston to #1 comp. an the turned the the gear so it would line up with the timming makes , an checked the comp. an I was getting 145 psi in the motor now. The 289 an the 302 are the same but the heads are diff. from what I can find out my looking an also it is what I could find for cheap . not to worried about the bottom end it will do what I want it is not a drag racer an I have a t-18 with a 205 t case . Rick
During normal operation, every other crankshaft rotation would be 2 rotations which would put the cam right were it was before rotation.
Even a single rotation of the crank would not be 180 out, it would just be in a different phase of the camshaft.
He wasn't 180 out, his timing marks were off and there not a whole lot you can do with the distributor nor the wires to remedy that.
The crank moves 2 revolutions for every single of the camshaft. Having the cam 180* just phases the engine "over" 1 crank revolution. Instead of a piston being top dead center on the compression stroke, it would now be on the top dead center of the exhaust stroke. As long as the camshaft was timed to a TDC, whether it was with the marks lined up, or 180*, no damage can occur.
The engine internals don't care either way. The only thing that does is the distributor. Simply rotating the distributor 180*, or moving the plug wires over 180*, or pulling the distributor out turning the rotor 180* and sliding it back in would have made the engine fire normally.
We are basically saying the same thing. I just noted that if you turn the crank 2 twice, the cam is back where it started. I only stated that b/c you used the term "every other crankshaft rotation" which would be 1 full rotation of the cam.
That's why I commented that he wasn't 180 out, that he just missed the correct marks.
Kionga
09-24-2005 11:15 PM
