Wheel offset/backspcing. Will these runs work for 33 12.5 r15 on my f150??? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Reload this Page >
Old 03-22-2012, 03:19 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
Found these online an want to know if they are correct for me to run 33 12.5 r 15 tires on my f150 without rubbing.
A set of four ProComp steel wheels. 4.5" hub spacing, 9.5" width, rim size is 15" 5.5 on 5" bolt pattern.
Will these work??? Pin to pick up tomorrow I they will
Old 03-22-2012, 03:27 PM
Midnite1987
He had theni on a 98 dodge
Old 03-22-2012, 03:47 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
bring a jack and tire iron and try one wheel up front. it will either fit or it wont, and you could then check to see if it rubs when turning.
Old 03-22-2012, 04:07 PM
Midnite1987
They're just the rims no tires on them right now.
Old 03-22-2012, 05:54 PM
GNR22's Avatar
GNR22
GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
I know for sure that a 10" wide rim with a 4" backspacing fits. 4.5" backspacing on a 9.5" rim might be kinda tight though
Old 03-22-2012, 07:48 PM
Midnite1987
I hd him measure he says 9.5" wide and 4" from the back of the hub to the back of the rim
Sandgnat
11-06-2015 08:59 PM
Chris Haynes
10-14-2015 09:29 PM
braap123
06-29-2015 06:07 PM
Dreamtheatre
11-21-2014 07:12 AM
mudweiser2
09-27-2014 09:48 PM
Quick Reply: Wheel offset/backspcing. Will these runs work for 33 12.5 r15 on my f150???
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
