want to swap a 5.0 out for a 5.8
Well the air/fuel mixture is alittle different on the 5.8 to 5.0. If you are running a stock 5.8 NOT bored you might be able to use your 5.0 computer. Mine has a very small cam, and bored .040 over, the 5.0 computer ran it, but it has lots more power with the 5.8 computer.
The 5.8 is wider, thats where you would have to modify the exhaust. It would actually be a good time for dual exhaust, if you want it.
Are you running duals from front to back? If you're running duals from front to back, then you should be ok, if not you just need to cut the driver's side crossover and then weld it back.
I believe when it comes to headers, there is a difference between the 5.0 and 5.8. You will laos need shorty headers, to keep from having to do a whole new exhaust system.
TexasMarkIII
04-28-2013 05:43 PM
richdavis69
03-10-2011 04:49 PM
