My 42' restoration! - back to the good old days!
The rebuild has begun!
Today has been primarily spent using wire brushes and the wire wheel to clean the **** off the old parts in preparation for paint! If you look back through the thread, you'll notice that everything was brown!! NOT ANYMORE!!
Radiator mount with new rubber pad I made -
Fitted with original parts, all cleaned and painted up -
Brake/clutch pedal assembly -
Polished foot plates and bolted to the chassis -
New brake parts -
Master cylinder fitted -
New transmission mount fitted -
Started on the rear leaf springs too! Will have the fitted by the end of the week!
New brake parts -
So I done more today! It's been a looooong day of cleaning and painting!
All the suspension pivot pins were a bit shabby, so I cleaned and polished them up,
Before
During
After
Cleaned up and sprayed some small suspension parts -
While all this was happening, the leaf springs were in a bath of oil!
Then when all the paint was dry, I set to installing new suspension bushes, theyre brass on this, knocked in and out pretty easy, then installed the polished pins and locking pins along with the oil bathed leaf springs -
And tomorrow's challenge -
It's gotta be stripped, cleaned painted and re assembled with new handbrake cables, wheel cylinders and brake lines! And it's covered in 70 year old grease, it's gone solid!!
Before
During
After
I got more for y'all!!
Set to work on the rear axle, stripped all the parts and then had at it with an angle grinder with wire wheel attatchment! What a beast of a tool!!
Then cleaned it with solvents and painted it black of course!!
Did the same with the brake back plates -
Hanging up -
Tomorrow I'll hopefully get it on the chassis, to form an over sized extremely heavy ford wheel barrow!!
Hanging up -
#30
This week was a bit of a bummer!
I wanted to get started on the front end -
Ended up in the emergency room with this -
Picture doesn't show it too well, but I've got 5 stitches and just missed nerves/tendons and muscles!
It was a 7/8" spanner by the way!!
This meant I can't drive, so I sent my dad to collect some parts that I had found!
Carb -
New wheels and oil bath air filter -
Hubcaps -
Trim rings - they were an optional extra back in the day apparently
New brake unions and wheel nuts -
Spark plugs -
Turn signal switch (ours is missing)
Dad also ordered more stuff! So I should hopefully be able to go get it in the next week or so!!
Carb -
Hubcaps -
Spark plugs -
