How do i time a 99 ford explorer v6 4.0 ohv
03-18-2012, 10:58 PM
on
I just replaced my stock engine with a rebuilt v6 ohv and was wanting to know if there was any way i could check the timing. It started rite up and runs i ran it for about 10 minutes and it got smoother than it was when it first started but still fills like it has a little miss in it like it is a little out of time. Does anyone have any help that they can give me. Thanks
03-19-2012, 06:55 AM
All timing events are handled by the PCM.
03-19-2012, 06:55 PM
on
So as long as the timing marks on both cranks on timing chain then when i set in the distributor it should time itself. The marks on cranks were at 6 and 12
03-21-2012, 07:09 PM
on
Gosh, my 96' 4.0Litre OHV engine does not even have a distributor.
03-22-2012, 07:24 AM
on
I wouldnt actually call it a distributor. It is the botttom half of one with a small plastic cap on it that has an electrical plug on it
03-22-2012, 08:06 AM
197K on ours...no timing adjustments just sensors
08-09-2015, 01:46 PM
on
dirty injector will cause a miss.. then the brain makes the other injectors pump more fuel because O2 sensor is detecting a lean situation from a clogged injector
rocker_topper
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
09-05-2007 11:15 PM
davepiper
02-26-2007 09:18 PM
dansmith
08-30-2003 05:02 PM
