3" drop I beams f100
Old 12-27-2007, 03:30 PM
MustangSteveTX's Avatar
MustangSteveTX
MustangSteveTX is offline
Suffice it st say that I am not happy with any of this aftermarket garbage. Seems like they throw anything out there, irregardless of quality issues. I have thought building my own from existing beams would be best way, but i did not know if the beams were heat treated and maybe the welding would not work right. So your truck had sectioned and rewelded beams and it worked OK?
  #77
Old 12-27-2007, 03:42 PM
ken selvy's Avatar
ken selvy
ken selvy is offline
No , thinkin of how I could do it with stock , our beams are forged and they say not to heat at all , they cold bend them for camber issues . Be nice to cut them at the spindle a inch or two back then weld a plate to that and make them adj up and down with correct camber , no one has done that yet . Wish I could draw it . Oh also another plate to the spindle end .
  #78
Old 12-27-2007, 03:48 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
Now that's what I would like a slide in fit without any detectable play.
I did a front end for a friends family ranch truck, you could
wiggle the pin and place .040" drill bit beside the pin. Camber was sick
plus no wedge pin. Pick-N-Pull beams plus new king pin kit I became a GOD
to them with free wine. This was a 67 at the family winery, grand dads rig.
The secret is use bronze bushings and ream with a king pin reamer made for this purpose only not your standard adjustable reamer. Lucky me I have a .860" king pin reamer somewhere within my stuff (wife calls crap).
  #79
Old 01-03-2008, 12:35 PM
boo-yaa138's Avatar
boo-yaa138
boo-yaa138 is offline
do any of you with the drop beams have any pics of them on your truck? i would like to see what they look like?
  #80
Old 01-03-2008, 04:54 PM
MustangSteveTX
Won't be long until I have mine on.
  #81
Old 01-03-2008, 05:09 PM
boo-yaa138's Avatar
boo-yaa138
which beams are you using and how low are you going?
  #82
Old 01-03-2008, 05:15 PM
MustangSteveTX
I have 3" DJM (read earlier posts) not sure about quality of kingpin tube inner diameter yet. Will post after I get it in there to see if I have to uas an oversized kingpin to fix their sloppy work.
  #83
Old 03-05-2008, 06:13 PM
boo-yaa138's Avatar
boo-yaa138
bump back to see if you got the drop beams in?
  #84
Old 03-05-2008, 08:26 PM
MustangSteveTX
Angry Dream Beam (or NIGHTMARE BEAMS)
Still have not installed. I got the frame painted and need to get the kingpin bushings reamed before proceeding further. I think we are going to insert some 0.003" shim stock in alongside the pins in the beams. I WISH AFTERMARKET COMPANIES WOULD MAKE DECENT PARTS!!!!!!!! After measuting everything,the holes are 0.010" oversized from factory. That would be great if this was a beam for a 67-72 as they make a 0.010" oversize kingpin for those. They do not make one for the 73-79 beams.
  #85
Old 03-06-2008, 08:33 AM
Villengineer's Avatar
Villengineer
Villengineer is offline
If anyone is interested I have pics of the AIM and DJM beams side by side in my gallery. I haven't gotten around to installing them, but I think I am going to go with the DJM beams and the AIM tie rod relocators. I don't have a set of the DJM relocators, but having seen a set, I wasn't real impressed. I'll have to check the king pin hole diameters to see what they are.
  #86
Old 03-06-2008, 08:35 AM
Villengineer
Originally Posted by shakedog
Or how about this?
Looks like it was cut and welded.
Those look like AIM beams, not cut and re-welded OEM beams.
  #87
Old 03-06-2008, 10:02 AM
ken selvy's Avatar
ken selvy
I like more drop and a little cheaper price with aim , heard so many stories about aim and not liking them , I like the construction of them better , seems the king pin holes are never perfect on both . Seen alot of trucks with aim beams and owners with no problems . Keep changing my mind about which 1s to buy , also waiting on marz project .
  #88
Old 03-06-2008, 02:04 PM
boo-yaa138's Avatar
boo-yaa138
i am also waiting on marz project
  #89
Old 08-29-2011, 05:46 AM
scottheimler's Avatar
scottheimler
scottheimler is offline
Originally Posted by jowilker
Let's get back to Ford trucks! This not the Ol Geezers whining forum.
-Moderator
LOL! Thanks for that. MY back was starting to hurt.
  #90
Old 02-13-2013, 02:28 PM
BrotherMabe's Avatar
BrotherMabe
BrotherMabe is offline
These are DJM "Dream Beams" and they work great on my '68...
Quick Reply: 3" drop I beams f100
