01 Escape 4cyl P301
Old 03-23-2012, 02:31 PM
oakfan52's Avatar
oakfan52
oakfan52 is offline
01 Escape 4cyl P301
I tryinbg to figure out whats causing a repeated P301 on a 2001 Ford Escape 4cyl. Idle is rough. I already replaced plugs, wires, and the coil. DPFE was also replaced recently. Could it be a bad injector or fuel pump?
Old 03-24-2012, 09:48 AM
critterf1's Avatar
critterf1
critterf1 is offline
Have you checked compression? How about a vacuum leak?
Old 03-24-2012, 10:48 AM
oakfan52's Avatar
oakfan52
oakfan52 is offline
What's the easiest way to check for a vac leak?
Old 03-25-2012, 10:34 PM
critterf1's Avatar
critterf1
Carb cleaner works well. I prefer using my smoke machine.
sandsOtime
21
10-20-2015 07:55 PM
02FX45.4
1997 - 2003 F150
29
08-26-2010 01:09 AM
garryk50
03-05-2008 09:22 PM
p.j.
12-26-2007 04:09 PM
1972argus
10-14-2006 10:35 PM
Quick Reply: 01 Escape 4cyl P301
