390 oil pressure
Rebuilt 428 running with low oil pressure...
Hey all. So I have been reading a lot about low oil pressure on FEs and have a decent knowledge about it but the following situation baffles me...
Summer 2012: Rebuilt an original 428 with all stock components. Started it up and it got hot and the oil pressure was down at 5psi and I shut it off... The intake gasket was leaking water into the oil and it was not a good situation.
Fall 2012: I pulled the motor and rebuilt it, installing a high pressure oil pump checking all the critical components and cleaning out the radiator. I took it out for a 45 minute test drive. When cold the oil pressure was ~65 psi and then when hot at idle ~15 psi. When I rev up to 3500 rpm the pressure jumps up to no more than 25 psi...
Is this safe? Any recommendations?
Our good 'ol sending units most always read low. Get an actual pressure gauge if you want an accurate reading.
Which is why some have gotten this idea that headers make the oil pressure lower because of the heat. Well, yeah, but that's because the oil sender is right near the front tube of the headers
Anyway...
luv2ski
09-26-2019 01:33 PM
Jolly Roger Joe
16
06-11-2018 11:14 AM
keisha9
12-01-2006 07:29 PM
