fuel leak help
fuel leak help
Hey guys, I have been smelling fuel the past day or so so i got under the hood and I'm leaking fuel out of the bottom of the fuel filter housing. Please forgive me I'm not sure what everything is called so i will do my best to explain it. It looks like it is leaking at the bottom of the housing that u take of to do the spring upgrade, its not a really bad leake but enough that it needs fixed. I hope I didn't lose you and i hope it makes sence.lol
And yes I check to make sure everything was tight, oh I just did fuel filters 2 weeks ago with OEM filters.
<TABLE style="WIDTH: 740pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=987><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><COL style="WIDTH: 95pt; mso-width-source: userset; mso-width-alt: 4608" width=126><COL style="WIDTH: 302pt; mso-width-source: userset; mso-width-alt: 14738" width=403><TBODY><TR style="HEIGHT: 37.35pt; mso-height-source: userset" height=49><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 221pt; HEIGHT: 37.35pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=49 width=295 align=left>Upgraded fuel pressure regulator kit</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=147>3C3Z-9T517-AG </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 95pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl69 width=126 align=left>
1843065C98</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 302pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=403 align=left>Upgraded fuel pressure regulator kit</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" height=17 align=left>Fuel pressure regulator cover "o ring" seal</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66>3C3Z-9C065-AA</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=17 align=left>Fuel Pressure Regulator "Spring and Reseal Kit Only"</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl70 align=left>6E7Z-9C165-B</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" align=left>1854267C94</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 302pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl71 width=403 align=left>Around $35 = o-ring and spring only (no cover)</TD></TR></TBODY></TABLE>
IDK if the second one down from top is the keyhole gasket or not the oring seal is throwing me off alittle here
If you havent done the blue spring mod now would be a good time
No yoou can reuse the Housing but to get the Keyhole gasket you might have to get the whole kit IDK some places will sell just the spring You will have to ask the parts guy
I went with the whole kit cuz I wanted all the gaskets and orings in case I need them
Yep very simple!!
Yes I could see that the bottom of the keyhole gasket was not making a good seal and that's were she was leaking from!!
I feel better that its don like you said. Thanks again man!
Blade you have helped me with a lot on this 6.0 from a egr cooler oil cooler egr codes and know the blue spring so thank you man!!
If your leaking fuel you could have low fuel pressure Fix that upper fuel bowel first
Low fuel press will kill injectors
also smell oil does it smell like diesel fuel watch for few see if your making oil for awhile I checked mine once a week for a couple weeks shure enough them injector orings was leaking
