1994 F150 XL Need Info on Airbag light !
Well, you must determine if you're getting power to the pump. A multi-meter or at least a test light is required to do that. Try the whack test. Take a runner mallet or similar and whack the bottom of the tank in the area of the pump. See if it starts working. mine did, temporarily, like 10 minutes. I can get the connector pinout for you to test it if you have a meter or light, and a helper.
You changed the SRS indicator lamp and there's still beeping???? Ok, if you changed the bulb then you're getting a code flashed?
My bragging about not ever getting a defective fuel pump just bit me in the butt. Put it in last Saturday, haven't moved the truck an inch, and went to start it this morning and NO FREAKIN PUMP WHIRRING! Plugged in my spare center tank pump......bzzzzzzzz! So I pulled it back out. Man I'm glad there's no bed on my truck! I'd have been ready to strangle the seller. Now to see if he makes it good, quickly!
Your beeping issue is screwy! If you replaced the SRS bulb and are seeing a LFC then it shouldn't beep.
You can do all the things you've done trying to make the pump work but the question I haven't seen answered is "do you have 12V on the red wire in the connector at the fuel pump"? See my connector photo above. If yes then your pump is bad. If no, where in the circuit is the last place you get 12V?
You can unbolt the bed and lift it up enough, one side at a time to sit it on short 2x4 blocks and slide it back far enough to access the center tank pump. I've done it several times by myself. It's not as difficult as it may sound.
Regular cab pump location.
My 95 Super Cab, with the bed slid back.
In the top photo you can see the wiring connector attached to the frame ( to the right of the pump) . If you pull it loose from the frame, disconnect it and test the pins mentioned above for power you'll know if the pump is getting 12V. Ignition will have to be on. These models have a check valve in the pump "module, as they call it, that prevents flow from tank to tank.
I'll look up the bulb but IIRC it's just a 161
Edit:
Just to prevent a major foopah, you do not have the dash panel off and the fuel selector switch disconnected do you?
The 161 or 194 is fine for the bulb.
Edit:
Edit:
Edit:
Ok unplugged connector going to fuel pump in the tank (front) , found a good ground , used tester to see in any current present coming to pump ,, at this point seems there is none ( light will not come on Tester ) ,, Ok would a bad Ignition switch cause this??? at steering column . if there was a bad connection could it cause the pump not to energize???? Or can I rule that out. I re hooked every thing in the dash as I went ,, little perplexing that the beeping didn't go away tho ,,, of course I did use another bulb from the cluster its self to see if it would stop ,, unless it needs to be a brand new one! Oh yes ,, I did run a wire from Pos at battery and tryed to see if pump would come on ,,, but I dont believe I grounded it while doing it ,, Now neighbor happen to have a volt meter ,, just need to know what to set it at , never had to use one before!!!!
Wait just a minute here!!! wow that is a tripped inertia ?? may be I ned to recheck that thing ,,, you know I kept thinking it would be all the way tripped up ! ,,, but if it is ,,, when I connected a jumper wire to it (connector ) shouldn't it (pump come on and code go away? ) What I'm trying to say here is mine looks like that pic tripped ,,, If I reach in and pop it up , it comes all the way up
#28
#29
When you turn key on it should energize the pump along with many other things right?
