1966 steering column
Never mind, that link was to Worm at Cen-Pen.
Here is a link to IDIDIT Dealers in the US. http://www.ididitinc.com/dealer_list...ealer_list.htm
Here is a place to start.
Garbz
Garbz
Probly salvage later model auto steering column from 'pick n pull' for around $50. Not sure what yr. tilt column was introduced, possibly another option, although would require refab and modification of the turn signal wiring harness, etc. Believe if donor column is in 73-79 yrs. should be able to swap mounting brackets and do away with the need to use spacers. Anyhow, food for thought.
on
I like 78 F100 or F250 tilt. Then do an aftermarket wheel or retro fit a 53 wheel. If your truck is two wheel drive with an automatic look for the same in the local junk yards or e-bay. The 78 tilt does not have the ignition switch on the column and unless you look closley most don't know you have a tilt. The only thing I do is swap out the dash loop bracket (cut the spot welds) or you could just use spacers on the 78 loop and bolt it in.
Big Mike,
I just got my 66 and am 6'6" with the same problem. I drove it home for the first time yesterday and have smudges on my shirt from the steering wheel rubbing....
I like the stock look, but would like the wheel to set 4-6 inches closer to the dash and away from my belly.
the best,
Wichita Sam
the best,
Wichita Sam
mmhoward
01-04-2011 03:32 PM
