4.6 liter install in 53-56 F100 anyone do it?
or do that swap to a carb and distributor that i mentioned so many moons ago from jailbait choppers and rods or something like that . i think they were wanting 1500-2000 and by the time you get done playing with wiring harnesses and ecu's and tuners , etc. you'll have that in it anyway .....................
I am putting a 2011 FORD MUSTANG GT 5.0L COYOTE ENGINE AND GETRAG MT82 6-SPEED MANUAL TRANSMISSION in my 1956. The motor will be here next week and I will be documenting all the fun issues I run into.
That' s pretty close to truck ****.
ford makes this reflash harder than others..
so you have to either my an add on board
or one of the programmers, and have it programmed with a custom load.
On my 5.3l GM, it was $75 to send the ecu, programmed and postage back.
on the 4.6l its $150 (used) programmer (SCT X3 ), $100 programming service(cheap), and I haven't even wired up the engine yet.
DetailZone will reprogram the 4.6l ecu for $350. I don't know what happens if u need a change.
Sam
Sam
Tom
That sounds way better than $350. I thought that was way too much. For my application I shouldn't even need a reflash. Not totally committed to this motor yet. I got it cheap ($300 with trans) without hearing it run but that Telorvek harness costs $760. And its' specific for the 93 4.6. That's a big gamble.
Tom
Tom
make sure it 'unmarried', else SCT charges $150 to reset.. (so $175 ($325-150) is as high as u should go, else buy new one)..
Sam
Tin Man Fabrication 109408 - Tin Man Fabrication Motor Mounts - Overview - SummitRacing.com
Sam
#30
Not trying to digress..and still stay on topic...somewhat..
I remember early in my hot-rod magazine reading years..thumbing thru a Hot-Rod magazine, and coming across someone out west (Colorado?) installing a big-block Oldsmobile Toronado engine/trans (front-wheel drive) in an el camino,..
living in the Mid-atlantic and learning how to drive in a little snow..and realizing how little traction the rearwheel drive chevy's were...it made perfect sense to me then... even at a young age, and still does...and I think that pretty much corrupted me.
