1999 ford f350 no power missing
So I was working on a 99 f350 and it would occasionally have low power and when you turn it off for a min and start back up it would be fine. So I did my diagnosis and found the ipr was sticking. I told the guy bring it back and I'd replace it because for some reason ford didnt have one that day. So then he told me that it was getting worst so he brought it in and I replaced the ipr and no more low oil pressure high ipr duty. Took it for a test drive and it was fine for about three blocks then started missing really bad and no power could barely go 15mph. The the highest the ipr got was 35% at about 2500psi icp. Noticed the fuel was pretty low so figured it was running outta fuel put fuel in and still same problem. I opened the fuel filter to look whats going on and it was obviously water and diesel. I don't know how much water compared to diesel it was but enough to not be diesel color and more of a clear white color. Im pretty sure I have to drop the tank and get good fuel in it but does that what it sounds like the problem is? Because before when it lost power before I swapped the ipr it would have about 1600 psi at bout 65% now the ipr doesn't get high and oil pressure is nice but no power and and missing. Plan on dropping tank unless someone points me to a different direction. I might be asking stupid questions that I pretty much answered myself but just wanna be sure I'm not going backwards. Icp at idle is about 490-530 at 10-12%. Thanks
If you suspect water, drain the fuel filter bowl into a clear jar and look to see how much water vs. diesel is in there since the two won't mix. The water will be on the bottom, the diesel on top.
Is the CEL on? Any codes? Have you checked fuel pressure? If you decide to drop the tank, be sure to take apart the mixing chamber and clean the cylinder screens inside. That or just do the in tank mods. Welcome to guzzle's In-tank Hutch Mod Web Page
Well guys pulled the tank drained it had it cleaned out and took apart the mixing chamber and cleaned out the filters inside and blew through all the lines. Changed the fuel filter and cleaned the housing and out good diesel in it and starts and runs fine now. Thanks for the help. I'm not sure if it was the water in the fuel or the clogged filters in the sending unit or a combination of the both but thanks for the help.
varminthunter243
08-07-2014 01:41 PM
