Econoline V8 - myth?
Old Jun 15, 2012 | 11:02 AM
jrnice's Avatar
jrnice
I'll have to look at the pulleys and see how they are configured. I never tried to pry them apart b/c I figured they were worth more together. But thanks for the heads-up.
Green was $10 + shipping, but I bought 2 C1UZ1190A for the front. So the bill was $26 for the parts and 9 shipping.
I have replaced a boat load of stuff already (king pins, joints, brakes etc.) and it drives nicely (as well as a basically 62 Econoline can). I wasn't happy to find a dead cylinder, but of all possible issues, I guess the bad valve was best. Seats were going to have to be replaced anyway.
Just got a call....heads are done.....!!!!!
Thanks again!
Old Jun 15, 2012 | 11:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you need another boatload, or whatever quantity of parts, lemme know...I'll look up the p/n, search to see how many are available.
Old Jun 15, 2012 | 03:22 PM
jrnice's Avatar
jrnice
Thanks for the offer! Any more boatloads will be a while. Heads were killer.
Shoulda bought a 302 HO
Old Jun 20, 2012 | 11:43 AM
jrnice's Avatar
jrnice
3A16: Block cast January (A) 16, 1963 (3).
NOTE: The waterpump and timing cover used before 8/23/64 are not the same as used from 8/23/1964.
The early 221/260/289 waterpump will not bolt to the later 289/302 timing cover. The T/C gasket is the same 1962/96, so the early timing cover will bolt to the later blocks, but only an early waterpump will bolt to it.
You do not have a 3 sheave crank pulley, because there is no such thing.
What you have is a single sheave harmonic balancer with either two single sheave outer pulley's, or a double sheave outer pulley bolted to it.
Accessory outer crank pulleys were used with dual belt alternators, P/S, A/C, T/E.
Since the engine was originally installed in a Passenger Car, it probably had P/S & A/C. No T/E until 1/1/1966.
Well I decided to change out the t/c to the newer one. Figured it would be easier to use updated alternator and get the filler tube out of the way.
Couple of the bolts were corroded badly...but finally got it off.
OK, crank pulley question....3 sheaves...clearly the C5OE-A (from high optioned '65 289 Falcon wagon) is assembled. 2 (double) inner and a 3rd inserted into those and and inner "hub" inserted in all that and appears spot welded together.
...compared to the 3 sheaves on the C2OE-6312-C , from this Econoline transplant, which appears to be a one piece cast unit. The back even looks like it is balanced. I can't see how this is designed to come apart??
I'm wondering if I would be better off replacing / updating the old crank pulley with newer as the old may be worth some $$ to help me recoop some funds from the heads. The serpentine stuff I have from the 5.0 HO won't fit inside the doghouse. I don't plan on running a lot of power stuff yet, but that is subject to change. It may get A/C and power brakes later.
Moving on, I am repacing the timing chain and gears as I think 5/8" is too much deflection. I will use the 5.0 HO timing cover and the old balancer since it bolts up. I am going to need to figure out how to add a timing pointer to the new cover. Old pointer is a boss on the left side of the case. I have not looked at the 5.0 timing pointer to see if it will relocate.
Engine (crank) is already .010 under and has a few miles on that. Rod clearance at .0035, so it's loose. I should pull it and freshen it up, but my short term goal now is just to get it back together to make a decent driver for intown. I'll probably change engine/trans/diff later.
Thanks for your input and research!
J. R.
Old Jul 22, 2012 | 09:07 PM
pennswoodsed's Avatar
pennswoodsed
Hi, I (we) put a 302 and c4 into Falcon Club Wagon,64? ,drive shaft ended up 21.5 " center to center on ujoints ,used rear from 240 or v8 van.Stupid fast considering handling and brakes . Oh and this was 1980,last Grand Prix at Watkins ,slept in van.
hogfan17
May 5, 2015 08:59 AM
fordf350camper
Large Truck
Apr 29, 2015 01:28 AM
mmac1318
Jul 30, 2007 08:15 PM
FPChickey
19
Feb 9, 2003 08:05 PM
gbastedo
Jul 26, 2000 01:31 AM
