3 hour MOD my @s$
3 hour MOD my @s$
Well its official, I believe I hold the record for the longest 6.0 tranny cooler MOD in the history of FTE. While the day started out with visions of a three or four hour mod, seven hours later I am finally done. Note to self, someone else’s instructions are never as easy as they first appear. So I followed the normal instructions like most others and I got as far as removing the grill. Well I have a winch that sits almost flush with the grill so that was a major delay. When I got to the part about “just take off the two top bolts and the two bottom bolts and slide it out” that is where the second delay occurred.<O</O
<O</O
I had no direct access to the bottom bolts as I still have the undercarriage crash bar or whatever that darn thing is and the bolts were not cooperating with my mod plans. I tried air tools and breaker bars and they would not break. Heck I would have sacrificed a chicken if I thought it would help so I just kept soaking them with PB until I could get them off (another hour wasted).<O</O
<O</O
Putting in the new unit, the damn clips kept falling off every time I came close to getting the cooler in position. Just when I thought about firing up the welder and tacking the damn things in place it finally came together. I love how the wife would look out in the garage every few hours and give me that “look” you guys know what I’m talking about. Hooked up all the lines and let it run for a while to make sure I did not have any leaks and put the old truck back together. If the other four mods that I have in the garage go this smoothly I think I’m going to call in reinforcements.<O</O
<O</O
I did discover that a weeding tool from the wife’s garden bag makes a great tab remover because trying to get them off with a screwdriver is one step shy of worthless. <O</O
<O</O
<O</O
<O</O
My wife's favorite saying is that it really isn't a true "repair" or "mod" unless it takes 3-4 times longer than expected, requires at least 1-2 extra trips to the parts/hardware store, and doesn't finish until after dark!
I've at least managed to avoid being up past midnight on repairs/mods now, but I'm still working on my time multiplier... hoping to eventually get it down to 2x the time estimate.
That is what I thought. One minute we were talking about putting the 6.0 in and the next thing I know Brians guys are done. I am thinking to 'myself'.... 'I' could have done that 'if' it was that 'easy'....... NOT
Tried to put on an oil by-pass last night….fail. Again, the instructions are not right. They call for a 3/8 extension to remove the plug next to the filter and it is not a 3/8th plug. 3/8ths is too big and Ľ is too small and it is square so I can’t use and Allen wrench to get it out. I did get the Donaldson ELF7405 on and the new oil drain valve so I guess I will have to wait until my next oil change to get this by-pass figured out.
The instructions say “using a 3/8” ratchet and 6” socket extension, remove the factory installed plug in the engine block located just to the rear of the full flow oil filter”. I’m going to look at the store and see if they sell a square set of heads for removing various plugs. If not I might have to make my own. I need to figure out what size this darn thing is.
