5 Star Per/Tow Tune? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 03-11-2012, 09:43 PM
ocboat
ocboat is offline
ocboat is gaining momentum as a positive member of FTE.
Lately, I have seen several posts where the OP states that they are using a (fill in the octane) per/tow tune. It reads like this is just one tune for towing or performance. When I ordered my tuner and tunes from Mike, there were separate tow and performance options. Are these performance/tow tunes something new, or are the posters just stating that they are using either a performance or tow tune?
Old 03-11-2012, 10:19 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
I'm not an expert on the subject, but I just bought tunes and it was a single tune for performance and towing. I also got an economy tune to mess around with also, but after loading up the perf/tow tune, I'm thinking I 'll stick with this for a while.
Old 03-12-2012, 12:41 AM
Bbasso's Avatar
Bbasso
Bbasso is offline
Bbasso is gaining momentum as a positive member of FTE.
I have 3 tunes, 93tow, 93performance and 87tow
But to find out the 100% correct answer, ask Mike.
Old 03-12-2012, 08:15 AM
ddbck's Avatar
ddbck
ddbck is offline
ddbck is gaining momentum as a positive member of FTE.
I think the Perf/tow tunes are only for towing under a certine weight like 8,000 lbs. If towing heavier you need just the Tow tune. Not sure on the weight check with Mike at 5 STAR. My 3 tunes are 87perf/tow - 89 perf/tow & 91perf/tow. My 24ft toy hauler weighs 7,000 lbs fully loaded.
Old 03-12-2012, 08:38 AM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
The Tow and Performance tunes are separate. The performance is mainly for when empty or lightly loaded and the tow is for towing.
Old 03-12-2012, 11:05 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
With Mike, I don't think there is any set-in-stone definition for each one. It all depends on what you want, and what Mike names them in the device
Old 03-12-2012, 11:28 AM
Fosters
Fosters is offline
Fosters is gaining momentum as a positive member of FTE.
If I remember right from ordering mine, the main difference between performance and tow is that while they both hold on to gears longer and rev higher, the tow one is more reluctant to go into o/d than the perf one.
Old 03-14-2012, 01:50 PM
ocboat
ocboat is offline
Straight from Mike himself: "5 speed trans trucks with tow/haul mode tune can be perf/tow tune based on that mode of operation, 4 speed trans trucks have separate tunes perf and tow shift and converter patterns change."
truckfella
Modular V10 (6.8l)
21
10-04-2018 09:10 PM
Amicus
12-04-2016 07:35 AM
oxt127
04-10-2016 10:13 PM
2gumby2
Computer Chips & Tuners
12-12-2015 08:30 AM
av8tor09
04-22-2012 02:38 PM
Quick Reply: 5 Star Per/Tow Tune?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
