What parts can be removed from a 6.4 ?
If you are tuned, have a tuner, how many parts can be scrapped off the engine?
We know yes, for:
EGR coolers
Intake elbow
DPF / exhaust
stock turbo
EGR valve
What about the fuel cooler?
Is it needed, or just used to stabilize the fuel temperature for emission reasons?
It would be nice to hack that crap out.
Anyone have any other ideas on what could be ditched from the engine bay?
We know yes, for:
EGR coolers
Intake elbow
DPF / exhaust
stock turbo
EGR valve
Not sure I'd remove the fuel cooler. High temp diesel has a different density and potentially loses some of what's left of the lubrication properties. Extreme pressures of the HPFP (I've heard up where of 20,000 PSI in the 6.4) cause high temps.
I am not sure if the "fuel cooler" is so much a cooler, rather a "temperature stabiliser"
Would be interesting to see what happens temp wise without it.
what is "PSA" ?
Yes you would, and also liquids to not simply jump in temperature from being compressed.
I'm not sold that the cooler is even acting as a cooler, I think it's just keeping the fuel warm, and stable, for emissions purposes only.
OK so I did a bunch of forum reading, and asked a few people as well.
I have a verdict now.
The fuel cooler is required, but the heat isn't generated by the pumps or anything, it's just the under hood temps and engine temps that raise the temperature.
The fuel that doesn't get used goes back to the bowl, so it can build up with heat.
If it went back to the tank, a small passive air cooler would be enough.
The vgt actuator also is cooled by this secondary cooling system.
What a frickin nightmare, I would love to throw a single turbo in and delete all that junk.
It would be awesome to delete the entire 2nd cooling system.
