So what did you do to your 6.0L today?
Old 02-12-2019, 05:43 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
It was 40-50 in the shop. Not super condusive to painting which likely played its role. I was having issues blocking and sanding the primer which was from my reasearch a issue with the product i used. I ended up stripping the primer back off and fixing what insaw thru primer as best as i could with out being able to do a guide coat. Then primed painted and cleared it. It isnt horrible but untill i devote more reasources to it, it will have to work. On a up note the pan spray bedliner does look the part. Though likely not as durable as a 2 part epoxy bedliner it will work and look better then any paint i wouldnhave laid on that panel. I guess at the end of the day i need to realize this is a cheap truck thats over 10yrs old with 346k it dosent have to be perfect.
  #21797
Old 02-12-2019, 05:48 PM
Lubbockguy1979
Here is the other side. Still need to be buffed and i need to hit the handle cover with material but ill do that tomorrow when i can move the tailgate
  #21798
Old 02-13-2019, 12:19 PM
copsey's Avatar
copsey
copsey is offline
Decided to clean the turbo while I'm waiting for parts. Glad I did, unison ring was stuck, cleaned it all up and lightly lubed with some anti-seize and she's moving beautifully now.
Should be able to get her up and running Sunday and have some power back.
  #21799
Old 02-13-2019, 12:55 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
glad you got to yours before it ended up like mine did.... replacing them things aint cheap....
  #21800
Old 02-13-2019, 04:30 PM
copsey's Avatar
copsey
copsey is offline
I'm very happy I decided to check it. Wasn't any point in not since I had it out anyway. Didn't think I had an issue but had noted boost not building over 20psi when pulling our camper. Though maybe the tunes from Gearhead had that set as a parameter with the 10k studded tow tune, will find out once I get it back together and go for a joy ride. The 20psi was shown on my boost gauge and through MAP on Torque Pro.
  #21801
Old 02-13-2019, 04:37 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
I had rebuilt mine just prior to having to do a top end rebuild... wasnt expecting problems this soon... mine froze up last time i went to town with it... ended up melting the vanes & turbine wheel... ntm fused the unison ring to the turbos core housing.... trying to remove the vanes i ended up snapping off one of the poles they ride on... essentially the things totaled now... waiting on my new one to arrive which should be here tomorrow...
  #21802
Old 02-13-2019, 05:45 PM
Lubbockguy1979
What turbo did you end up going with? With a bad core it makes the powermax seem even better id bet
  #21803
Old 02-13-2019, 05:48 PM
Lubbockguy1979
Well im ahead of schedule. Took some finess with the brackets the rubber stops and the latch posts but she's on. Looks better then no tailgate.
  #21804
Old 02-13-2019, 05:59 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
KCTurbo Stage 1... unless i was going with bigger injectors the 1.5 was just too much for me... while itd work with the stock ones the turbo would out perform the turbo itself leaving the top end to kinda fall flat... with the stage 1 ill be able to pull end to end without suffering top end loss and the bottom end will still be responsive..
https://kcturbos.com/collections/6-0...e-1-61mm-turbo
already got my new tunes and 3 new pyrometers waiting to go in.... if the ground wasnt so soggy id be working on the pyros today...
  #21805
Old 02-14-2019, 01:05 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Today the guy in the big brown truck brought me a box
and inside that box i found this mean looking thing...
cant wait to get it into the truck and see how loud she screams....
but i still got some other things to do first...
  #21806
Old 02-14-2019, 05:05 PM
jezarie's Avatar
jezarie
jezarie is offline
Replaced MAP.sensor
Who knows what tomorrow holds...maybe replacing the turbo, too 😏
  #21807
Old 02-14-2019, 05:09 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
anyone happen to know how much weight is on just the front end of these trucks?? need to get the front end of the truck up in the air and not sure if ill crush my ramps or not...
  #21808
Old 02-14-2019, 05:52 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
My truck is heavy so for your truck it should be under 5k, probably closer to 4k.
I keep a pair of ramps around that I made from solid pressure treated 10x10 wood. Haven't crushed them yet.
  #21809
Old 02-14-2019, 06:14 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
4,000 is about right.
I don't recall the exact number.
  #21810
Old 02-14-2019, 07:43 PM
namnguye's Avatar
namnguye
namnguye is offline
Today I am in the process of putting in a by pass oil filter. I got the mount bolts in. I am ordering some fittings and a hose. I also plan to add a valve, so some more fittings needed. I am excited to see how well it works.
Quick Reply: So what did you do to your 6.0L today?
