So what did you do to your 6.0L today?
Looking for popular threads here, to let my 6.0 friends know, before I go post an ad in the For Sale section, that I have a friend with a screaming deal on a non-runner 6.0. Rust-Free CA 4x4... Anyone interested, PM me for details. I think that's about all I can say without breaking FTE rules...
Scott
Scott
I did make a shroud out of the shelf boxes. I really need to devise a good water trough for it. I have 3 or 4 of the pads and 3 fans. Had thought about scrapping a blowe assembly from a gas heater to increase cfm then use multiple pads. Just havent been bored or hot enough... i need to jum on a evap while its cold i almost scored one of the super large porta cools for 150 bucks a month or so ago
Fixed my toolbox locks. I put a short rubber hose on the lock metal stick to make it not bouncy and absorb shocks. Works perfectly.
I also poured a bit more than specs the fuel cetan booster and winterizer additive. My fuel pressure shoots up from 63 to 70 psi. Not sure because of that, but it probably is. Truck runs smoother also.
How often people have problem taking their 6.0 through car wash? The north east salt really scares me. In the morning, there are lots of water condensation beneath the truck due to freezing cold metal the night before.
service things with the stop bar. One of the really nice ones they changed the way you get into it and I can't make the corner. They have a really nice one in Spokane that is HUGE and trucks out trucks fit really well.
Not a problem if you can find the larger tunnels. SRW I think is the only way you will fit. Ask the operator if unsure. Fold the mirrors in. I have 2 that I can no longer get into around here because they put in the stupid self
Removed oil cooler and HPOP cover. I had replaced the hpop a while back with an adrenaline pump. I didn’t use the Ford sealant, I used an anaerobic sealant I trusted. That was a mistake. So I’m resealing that and figured as deep as I had to go I may as well replace the oil cooler at the same time. Deltas were not terrible. Typically running 9-12 depending on ambient temp. Also have some connectors that will be replaced, specifically the oil temp sensor and VGT.
Should have all parts in hand for the weekend to reassemble.
Dont you absolutely hate itnwhen a project just wont turn out how you want it too. Paint and body is outside of my wheel house but i thought i could make it work. Part of the problems might be from not using 2 part body filler, 2 part primer.... but for today i guess whe will have to do. It will be better then it not being close in color
looks better than i can do Randy.... the rippling there in the pain ive heard described as Sags/Curtaining.. supposedly its from holding the gun too close when shooting the paint.. been told Red, Black, White and anything with metallic are the hardest to shoot and get matched... Black simply because it shows off every imperfection in the body... White and red just mainly because its hard to get the shades matched... Red unfortunately gets bleached by the UV rays and does so at different rates making it really hard to match.. throw the metallic in there and just adds to the problem... feel free to come by and help me with my painting projects.... i got a white truck and a black mustang that need some touch ups...
Thanks for the compliment. Its a learning endeavor for me. Stuff i could pay to have some one do but i want to learn or im too cheap.... pick your evil. This was duplicolor rattle cans and with 2 cans of clear it looks alright. As with anything i notice the imperfections right away. I would like to repaint the truck at some point as the clear is peeling in places and rust is bubbling thru other places. Maybe i will step up to a compressor driven setup and better materials then i think id also like to step away from dark toredor red and do the ruby red metallic like my 2016... its alot prettier when clean... im down to try most things next project truck wise is a rear bumper and rebuilding the driver seat cushion nw heater and a new cover. But i might be modding a cheap offset smoker i picked up for about the cost of a brisket
How warm was the are that your were painting in?
Metallic paints are hard to get right when you have not done them before. Practice is how you learn.
When your up to get get a good compressor that can feed a HVLP gun. They like the air so you need a good CFM output.
For rattle can not too bad. They can be a pain as you can't do any Boxing of the paint. (Boxing paint is when you dump all the paint into a larger container and blend it)
