So what did you do to your 6.0L today? - Page 4 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
  #46
Old 03-16-2012, 01:51 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Yep, KR with Harley headlamps. Those are just inserts in the grille. I don't have a close up, but you can see it a little better in this pic:
  #47
Old 03-17-2012, 02:30 PM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.
Thought so...They look good i think id like to put the HD lights in mine since all my rear lights are smoke led, would be a good match
  #48
Old 03-18-2012, 12:06 PM
mohle's Avatar
mohle
mohle is offline
mohle is starting off with a positive reputation.
Installed a bush guard I picked up for cheap. Heavy duty military one. Have to still sandblast it and paint it, but I wanted to make sure that it fit properly.
  #49
Old 03-18-2012, 12:59 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
Did first start-up of the company's 6 liter F550 after doing head gaskets, oil cooler, ARPs, etc.
Found a few ATF leaks but nothing that's not fixable.
  #50
Old 04-07-2012, 07:49 PM
Piolet's Avatar
Piolet
Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
Today I installed my Fumoto block drain plugs and took a coolant bath in the process. Also replaced my thermostat.
My plugs were stuck pretty good and even a breaker bar wouldn't budge them for me, the 8mm allen was beginning to round the plug.
I had been anxious about trying an impact gun on them so I left them be. Well today I had nothing better to do so I said what the hell, and it worked! I remember a few guys were in the same boat as me and also not sure about using an impact on the plugs, but about 2 short pulses on the trigger and they finally started to turn.
  #51
Old 04-07-2012, 08:59 PM
bismic's Avatar
bismic
bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
You gotta LOVE impact guns!
I didn't work on it today, but I did order the Atlas 40hp FICM tune for one of my FICM's!
  #52
Old 04-08-2012, 06:33 AM
CAMPINGTOM
CAMPINGTOM is offline
CAMPINGTOM is starting off with a positive reputation.
Did coolant flush and new thermostat. Finally got my ect to 192. (Been running low 180s for a long time).
  #53
Old 04-08-2012, 08:54 AM
greentree ford
greentree ford is offline
greentree ford is gaining momentum as a positive member of FTE.greentree ford is gaining momentum as a positive member of FTE.
I got mine started, first time in ten days, new ficm, im back on the road and could not be happier
  #54
Old 04-08-2012, 10:42 AM
phantomphixer's Avatar
phantomphixer
phantomphixer is offline
phantomphixer is gaining momentum as a positive member of FTE.
Did a brake fluid flush and power steering fluid flush last night. Surprised me with the brake flush. Brake pedal now higher and lost a some mushiness. Didn't realize it until after flush/bleed.
  #55
Old 04-08-2012, 10:51 AM
berick's Avatar
berick
berick is offline
berick is gaining momentum as a positive member of FTE.
How many miles on your truck?
  #56
Old 04-08-2012, 10:14 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
Checked oil. Drove it.
  #57
Old 04-09-2012, 05:50 AM
wulfman
wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Had leak around thermostat housing and thermo was getting a little slow so put in new thermo today stopped leak and temps are higher .
  #58
Old 04-09-2012, 05:13 PM
phantomphixer
It was a good weekend for truck work. In addition to power steering and brake fluid flush.....
Also installed Marinco heater recptacle in front bumper rh side and installed Marinco trolling mounter outlet-to be used for my battery charger- in front bumper lh side.
Next project is rear bumper LED backup lights-mounted in the bumper.
  #59
Old 04-09-2012, 05:49 PM
johnnygalindo
johnnygalindo is offline
johnnygalindo is starting off with a positive reputation.
I`m new to this and need help, have a 2005 F250 6.0 4x4 and my TOW HAUL light is on , it will not turn off .
  #60
Old 04-09-2012, 06:04 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
I cleaned my EBP sensor and tube. Trying some things to get VGT% lower at hot idle. Cold idle it is 69%, hot low idle 85%.
Quick Reply: So what did you do to your 6.0L today?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
