So what did you do to your 6.0L today? - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
  #31
Old 03-13-2012, 03:29 PM
texastech_diesel
texastech_diesel is offline
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
The draw on those is nothing, something like .07-.08A, so if you wanted to you could run a wire with a diode added from the truck's harness for the back up lights into your pigtails and they'll come on in reverse, but also on command by the switch. Or you could switch the wire from the backup lights, and run them as Off---on w/ backup---on manually.
Looks clean, great install
  #32
Old 03-13-2012, 07:32 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Had this done last week:
ARP head studs, OEM head gaskets, standpipes & dummy plugs, injector o-rings, 1 piece branch tube connector & a Garrett Powermax
  #33
Old 03-13-2012, 09:33 PM
John Irwin
John Irwin is offline
John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.
Put a new sat antenna on - wiped the old one off driving into the parkade at West Edmonton Mall last fall. One of the biggest malls in the world, and you can't drive a Superduty in to park. I was hanging out the window checking clearance driving out, lots of paint from the roofs of the lifted trucks. You come off the street, no warnings, no way out, cars piling up behind you..you are committed... Idiots.
Also put my glowshift guage pod in. Not real impressed, I can't pull the sun visor down without twisting everything around, button doesn't work on one of the guages, and since the truck reads most of the values, would have been nice to just plug in instead of tapping into the oil and cooling system. Haven't done that yet, anybody know where to tap in at and what size of metric/NPT adapter I need?
  #34
Old 03-13-2012, 10:43 PM
groppin's Avatar
groppin
groppin is offline
groppin is starting off with a positive reputation.
Put new exhaust today. 4" MBRP. Pain in the but by ur self and no lift but I like it
  #35
Old 03-14-2012, 12:06 AM
kbuchheit's Avatar
kbuchheit
kbuchheit is offline
kbuchheit is starting off with a positive reputation.
Changed the oil and filter, greased her up and topped everything off. Ran through all the xguages installed on the scangauge to verify things and programmed to 100 hp with the predator for springtime. Gee I forgot how good that feels! Gotta love leaving the tuner cars in your black cloud at the stoplight!
  #36
Old 03-14-2012, 12:31 AM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
did my oil change today. also, installed my updated HFCM drain plug. she still runs great. over 100,000 miles. never a WIF light. never had to drain at all. no water in fuel when i removed old plug to put in the new updated plug. then again, i use chevron or texaco diesel and always a bottle of motorcraft cetane booster on ever fillup.
  #37
Old 03-14-2012, 07:59 AM
F250W6.0
F250W6.0 is offline
F250W6.0 is starting off with a positive reputation.
Great Idea
Originally Posted by phantomphixer View Post
Install 2ea 12 Volt charging outlets under rear side of front seats for passengers to charge cells and ipods. That removes a lot of clutter with everyone trying to plug in the 2 dash outlets.
Great Idea ,can you take pics and give an amateur instructions? Thanks
  #38
Old 03-14-2012, 08:38 AM
Bigdaddybus's Avatar
Bigdaddybus
Bigdaddybus is offline
Bigdaddybus has a good reputation on FTE.Bigdaddybus has a good reputation on FTE.Bigdaddybus has a good reputation on FTE.
I installed a coolant filter after getting my truck back last week with new heads, ARP's, EGR delete, oil cooler, and tuned.
The amount of grit in that upper coolant hose that you have to spice into by the oil filter was unbelievable to me. For those without a coolant filter I highly recommend one. I can see how people are replacing coolers over and over.
For $120 and less than 10 min of work, its a good investment
  #39
Old 03-14-2012, 09:24 AM
raptor131's Avatar
raptor131
raptor131 is offline
raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.
Crap I missed again, I installed series 5000 air lift air bags yesterday. I would love to shake the hand of the guy that can do it in 2hrs start to finish. It was more like 4.5 for me, but I do triple check everything I do. And drilling 4 1/2inch holes in the frame with a dull bit was real fun. Also had to guess as to unloaded weight, got close to 1000 pounds in my bed I can't take out so I jack the frame off the suspension to get them installed. Now I got to install the compressor setup
  #40
Old 03-15-2012, 12:58 AM
dukie1877's Avatar
dukie1877
dukie1877 is offline
dukie1877 is gaining momentum as a positive member of FTE.dukie1877 is gaining momentum as a positive member of FTE.
I unlocked my hubs :P
  #41
Old 03-15-2012, 04:28 PM
wulfman
wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
I put almost 4 dollar a gallon fuel in and drove the hell out of it going to diff jobs. and it was fun
  #42
Old 03-15-2012, 11:03 PM
dukie1877's Avatar
dukie1877
wow wulfman diesel is 4.45 here
  #43
Old 03-16-2012, 12:06 PM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.King-bRanch has a spectacular reputation.
Originally Posted by raptor131 View Post
A truck without a turbo..... I can't make out the rest. What does it say?
A truck without a Turbo is like a man without *****
  #44
Old 03-16-2012, 12:16 PM
King-bRanch
It wasnt today but not long i did the "Seat Heater Indicator" mod i seen on here awhile ago & it turned out great
  #45
Old 03-16-2012, 01:35 PM
King-bRanch
Youll feel good now knowing its done but i dread the day i have to pay for all that (cause it will happen)
BTW...is your truck a "king ranch" w/HD headlamps ?
The grille looks good too, any close up pics of the front end ?
I would like the Harley headlights in mine since i have all aftermarket smoked led rear lamps, i think smoke blends well w/the Copper paint
Quick Reply: So what did you do to your 6.0L today?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
