So what did you do to your 6.0L today?
got the "sensors" wired into the truck today... essh that was a nightmare to do... now i just need to make a mounting bracket for the gauge pod and then i can put the pod in the truck and plug the gauges into the sensors... also discovered i need to get a new turbo to intake tubing boot... saw they make one 3" long... the one i have is 2.5" long and comes up a little short on the new turbo...
Got the mounting bracket made for the new gauge pod.. itll hold onto the other one and support it on the bottom as well against the floor...
I swear it looks like an old set of TV rabbit ears when its not up with the other pod...
now im just waiting for the paint to dry so i can install it...
Failed the annual inspection last week so had to get the bed rails replaced - completely rotten. Took it to the local agricultural workshop which was quite amusing - got a strange look when I asked in my best French if they could repair my car. The foreman just looked at me and i said but it's a big car. They did a great job, cleaned and painted the chassis as well, and the steel they used will probably last longer than the rest of the truck.
Tester took less than5 seconds to ok the work.
Followed it up by replacing the expansion tank and all the hoses the ferrets had been testing their teeth on, hopefully no more leaking.
Got the gauges in finally... but when i tried to see if theyd light i ran into 2 problems... 1 a nearly nearly NEARLY dead battery.... (like lights barely lighting on the dash kinda dead).. put the charger on it still no gauge lighting on the new ones...
10 mins of trouble shooting later can you see the problem???
felt like a dummy when i finally found it...
also got the last of the intake in... like the new box i built??
it lives again... stomped on the throttle once down the on ramp from a dead stop and was at 90 before i knew it... moves alot better now than its ever has... doesnt feel like its pulling a cruise ship anchor behind it no more.... boost gauge shot up to 30psi when i stopped on it at another point...
Well I managed to sell my extra rear bumper and the extra tailgate I had from when I went to Idaho and picked up the bed that went onto my truck.
Now if only I could sell the bed. You would think that $400 for a work truck bed would work. So far no bites on that. If the bed is still here in three
more weeks I can see it having a date with the plasma torch.
A few years ago I took a load of scrap and got $100+ for it. A month ago I took scrap and got $25. Yeah, just getting rid of it to clear space out is worth the hassle of making a mere $25.
