So what did you do to your 6.0L today?
I know this Racor CCV4500 should be in Marketplace, but I've never got any traction over there. Maybe 6.0s need a selling thread.
I ended up with two due to a senior moment. Didn't clean it up and it's a bare housing. $100 and I'll pay for shipping Cont USA before it goes eBay.
Scott
Blue Spring Mod
Hey guys, only my second post, although I've been surfing the 6.0 site since August 17, that's when I bought my 2004 F-350 DRW. First owner took real good care from what I could see by the reports I pulled. Second owner...not so much so in that he shelled out about 15K for engine & transmission repairs by a very reputable local diesel shop. The 15K I paid him I suspect was his wanting to get back the repairs cost and he ate his purchase costs.
Today I changed the Blue Spring mod after getting my fuel and oil pressures gauges running last weekend, it was driving me nuts that I was only seeing 50psi on the fuel, even though I have receipts from PO showing the mod done two years ago.
Fuel on the left with the blue spring mod, according to the receipts from PO.
OEM blue spring on right, what I pulled out on the left. Is it possible that the spring on the left is a blue spring?
After priming and running I'm now seeing around 60psi. Still wondering about the other spring I swapped out, but at least I'll sleep tonight knowing for a fact what's in the truck.
ordered a OEM switch , this morning I tried the passenger front switch and it went down , but didn’t want to go back up , went to the drivers side switch with one hand on the rubber door boot and started pinching , found it to be shorting there.hopfully the rear window is the same or switch related , more to come on my findings .
I took apart my IPR metal coolant filter yesterday after 15,000 miles of driving. When I got my 6.0 some 45,000 miles ago, the coolant looked like swamp water. I run Peak ELC made for diesel. Today, the coolant looks like pomegranate juice. The filter had some a small amount of gritty material. It so clean that I wonder how the previous owner could have gotten it so dirty.
I changed both fuel filters. Same story. Clean!
Changed the oil-dirty! I tried installing the FS2500 bypass oil filter and wrote a huge thread on the install. Long story short, it's going back to FS2500.
I have been living with a rhythmic sewing machine chirp for nearly a year after I changed out my alternator and serpentine belt. It may be an alignment problem. Or it could be a bearing. I want to pull the bracket off the radiator to slide the radiator back and get enough room to inspect the pulleys and tensioner. I have the van, so it's an all-day project whenever I "get under the hood".
I gathered all my tax documents today. Sending everything to a tax attorney on Monday. Time to go back to my van for some relaxation!
Blue Spring Mod
Yesterday I did a OEM Blue Spring Mod. After getting the Fuel and Oil pressure gauges running last week it was bugging me that I was only seeing 50psi on the fuel. According to the receipts I was given from the PO a Blue Spring Mod was done two years ago.
Fuel on the left with Oil pressure on the right. Never saw the fuel psi above 51.
Spring I pulled from the fuel bowl on the left with the OEM on the right.
Now showing the psi I've been reading about.
Got the turbo back together and in the truck...
only took me 3 times to get it stuffed back on top of the engine... KC changes the orientation of the Compressor housing bolts.. so instead of them being on the front side of the compressor housing theyre instead on the rear side of the compressor housing... this became a problem because one of the bolts decided to push against the drain tube keeping it from seating in the hole...
i pulled the turbo and tried to reclock the housing so that the drain tube cleared the bolts... unfortunately when i put it back in and it seated on the tube i then discovered that the intake outlet on the turbo was way too high.. ended up bending the boot 90* when i tried to test fit it... so out it came again...
this time i clocked the housing the opposite direction and stuck it back in... this time it was a fight to get it back in.. but eventually it sat on the drain tube.. bolted the turbo down.. got the down pipe reconnected and the oil feed tube in... but thats as far as i got i was tired of working on the truck today after fighting with that thing all day... the up pipes are still disconnected from the turbo and the piping from the air filters still not connected.. havent changed out the manifolds yet (reason i havent connected the up pipes to the turbo yet.. figured itd be easier when i disconnect them from the maifolds). and still need to install the EGT probes...
ntm i still need 2 new batts.. but lets get the truck back together first before getting batts..
took the boot out of the door only , tomorrow I’ll get the whole boot slide back so I can see the wire loom , I’m definitely not getting power to the passenger front window , pulled fuse 32 and 41 and the Relay , could it be the Relay even though I still have radio and drivers side rear and front windows working ? , hopefully the switch will come in , before I start tearing things down to far .
My belt talks to me on shut down. A customers 7.3 did it on cold starts and was the water pump pulley. Good luck on the hunt, it can be tough to track sometimes
Before going nuts I'd suspect the belt making the chirp. The water pump pulleys can cause this. Do like Jack said, loosen/remove the belt and start it to see if the noise stops.
