So what did you do to your 6.0L today?
on
Now you know why we all cut them doing new exhausts. If you don't have a welder you could use a stainless band clamp to reassemble. They are really strong clamp with 3/8 hardware and grip the entire circumference. I get them from Napa and they are actually affordable.
Once those are back, I will install it.
Finished up HPOP cover reseal, turbo clean and oil cooler Saturday night. Highest delta I've seen since is 4.2 degrees at 189ect and 193.2eot. And the best thing is, no more leaks!
Also have a random knock from the front end, can feel it in my feet and assumed sway bar bushings or end links, all seems tight as can be there. Ball joints are tight and wheel bearings are as well. Don't see anything out of the ordinary but will continue to check as I go, something is goofy there.
Take a close look at the track bar on both ends. The bushing and/or the ball joint on the axle end can and do fail. I did both on my last truck.
Also the bushing if the bolt is not torqued right can fail. Too loose or too tight can take it out.
Today I got another brown truck visit with a box. Now I have all the kit and it's time to install.
For about 8,000 miles.
i popped the old bushings out and put in poly bushings... clunking continued till i popped the bushings out of the frame side spring shackle bushings... polied them and no more thump thump rattle rattle...
Good to know. I've got poly for everything in a box, just need to get them in.
have fun... the only annoyance i had with the drop links is the stock bolt is a bit too wide for the washer/sleeve (not sure which it was catching on) thats supposed to feed through.. i bought some grade 8 bolts to fit there... also had to play a game of research to get the ones for where they connect to the axle... ford lists my size sway bar but denies it was installed.. so no aftermarket company made a "Kit" for my truck... had to find what ones actually fit to put on the truck..
With cold weather here, I haven't been doing anything to the old beast other than normal maintenance routines and preventive checks, but yesterday I finally bit the bullet and installed an Atlas 40 tune, courtesy of Ed at FICMRepair.
Fired it up, eased through the back streets to get everything warmed up then turned onto a long straight stretch of highway and checked it out. Dayum!!!!!!! I should have done this years ago!
Highly impressed with the difference
