So what did you do to your 6.0L today? - Page 1408 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
  #21106
Old 11-04-2018, 07:33 PM
F0rdF0rever
F0rdF0rever is offline
F0rdF0rever is starting off with a positive reputation.
I started replacing my cab mount bushings today. I got 6 out of 8 done. The two front mounts at the radiator I wasnt planning on touching today. Im going to find a friend to help me with those two.
The front passenger side and the drivers side middle were so stuck from rust I wasn't able to separate the sleeves. While trying to pound out the drivers side middle with the large bolt from the rear mount I wrecked the threads in the cup. I was able to put a nut and bolt through the cups just to get it back together. I finally cut the sleeves in half on those two. I'll have to find those parts and get them replaced. Anyone have part numbers for those to sleeves sets?
  #21107
Old 11-04-2018, 08:26 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Wow that sounds like a PITA kind of problem. Did you spray then down a
day or two before starting the work? That might help wit the front ones.
  #21108
Old 11-04-2018, 08:49 PM
F0rdF0rever
Sure did. Sprayed them down everyday last week.
The problem is you cant really get penetrating oil between the sleeves.
  #21109
Old 11-08-2018, 10:01 PM
TxMav's Avatar
TxMav
TxMav is online now
TxMav is gaining momentum as a positive member of FTE.
Cab mounts
I just did the 4 corners of the cab. The middle and fronts are good and I donít have any help anyway. It was a job but I was able to knock it out by myself. What a difference.
  #21110
Old 11-08-2018, 10:30 PM
Ford.Dude's Avatar
Ford.Dude
Ford.Dude is online now
Ford.Dude is gaining momentum as a positive member of FTE.
Listened to the rattle of what I believe it to be, a ball joint, on the way to and from work.
Ordered 2 timken hubs, 2 sets of mevotech ball joints, and a rancho steering damper yesterday. I hope this is an easy task.......all are original.
  #21111
Old 11-09-2018, 12:56 AM
markw365
markw365 is offline
markw365 is starting off with a positive reputation.
Never heard of Mevotech. I did toss a bilstein damper on mine when I got it along with 5100 shocks (stock height). Been slowly collecting front end parts.
  #21112
Old 11-09-2018, 05:31 AM
amthatiam's Avatar
amthatiam
amthatiam is offline
amthatiam is gaining momentum as a positive member of FTE.
I used the Mevotech ball joints when I rebuilt the front steering on my truck, look to be very well made, greaseable, look to be well made. Rockauto sells them.
Dan
  #21113
Old 11-09-2018, 09:38 AM
Turd-250's Avatar
Turd-250
Turd-250 is online now
Turd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant future
some days it really gets to me not having any help, i have no idea how i get stuff done sometimes lol
  #21114
Old 11-09-2018, 09:40 AM
Turd-250's Avatar
Turd-250
first cold startup below freezing today with the new FICM! started so much faster than last spring. and has completely exposed my sticky injector(s)!
  #21115
Old 11-09-2018, 07:30 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Posting Legend
Sparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputation
proof that XDP does listen to suggestions for products...
https://www.xtremediesel.com/xdp-60l...t-y-pipe-xd284
ive seen many of us comment on the factory plastic y-pipe coolant connection failing/cracking... XDP has finally answered with this solution to this problem...
  #21116
Old 11-09-2018, 09:34 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold
That didn't take long. I emailed them when mine broke in August and they did respond and acknowledge. I asked since they already made one for the 6.7l. I guess they heard from enough people.
  #21117
Old 11-09-2018, 09:39 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Posting Legend
just one of the many reasons i have them in the top 3 for my diesel truck parts...
  #21118
Old 11-09-2018, 09:51 PM
87crewdually
https://www.ford-trucks.com/forums/1...l#post18169478
Found the post response from XDP. If I remember right Jeremy isn't the forum user anymore here but they use his account to respond.
  #21119
Old 11-09-2018, 10:10 PM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
TooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud of
Jeff uses the address.
Damn, and here I have a brand new OE one sitting in a cardboard box after Pete's issue.
  #21120
Old 11-09-2018, 10:50 PM
Ford.Dude's Avatar
Ford.Dude
Sparky may have been the "catalyst".
Surely I've ordered something from them. Can't really recall but I do know riff raff gets most of my money for the 6.0. I hate window decals but do like to support good products so all the decals go under the hood. I don't buy alot at cloths at clothing stores so I like to buy shirts, hats, and hoodies from places I've had good business with. Just got my son and I a hoodie from riff raff. Besides those clothes are reasonably priced compared to stuff at clothing stores. My daughter loves her flatbill ford powerstroke hat from dpp in Missouri. They don't sell parts but they are just a small joint with a great selection of ford hats.
But back to XDP, that says alot about their company tho. Makes you want to buy from them just because they simply deserve it. Quality is at an all time low anymore. Sad that buyers actually have to research a company before they purchase.
BTW, under the hood looks like a 1980s trapper keeper minus the garbage pale kids stickers.
Quick Reply: So what did you do to your 6.0L today?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
