So what did you do to your 6.0L today? - Page 1361 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 07-14-2018, 02:40 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is online now
Excurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant future
Originally Posted by Yahiko View Post
Useing something like the Radvac to fill the cooling system removes almost all bubbles in the system.
I have the Ex in the garage right now because the floor is flat. I drove it earlier today on some errands to get it hot. I am sure there is air in it but I am getting it out. I took the small return hose off of the degas and fillled the hose with coolant repeatedly using a turkey baster, the liquid definitely was displacing the air. I ran it again and it is cooling down,
  #20402
Old 07-14-2018, 06:31 PM
IHateCommieCars's Avatar
IHateCommieCars
IHateCommieCars is offline
IHateCommieCars is gaining momentum as a positive member of FTE.IHateCommieCars is gaining momentum as a positive member of FTE.
Cursed the PO of my shuule bus today. Changing tranny fluid and fuel filters - all the caps were torqued on. Got the tranny and lower fuel caps off but the bolt head on the upper fuel cap broke completely off.
I assume the only way to get it off now is with hammer and chisel. There's not much access on these Eseries. I broke one before and did that, Can't recall if it was a truck or van. IIRC I actually broke a hole in the top getting it off. Sure don't want pieces falling in the bowl.
  #20403
Old 07-14-2018, 10:57 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Posting Legend
Sparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputation
Shawn that valve is open until you go max A/C then it turns off.
well then there goes that ider... no clue where it went then...
  #20404
Old 07-15-2018, 02:06 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
If ony it was an Ex then you could blame the back heater core for the MIA fluids.
Well I got the steering gear into the project truck and can't find the bolts that hold the drag link. Never fails that some thing
would be missing. I looked in the box that I put all the hardware from the front and no love. Guess I'll have to go buy some
nuts. I'll take a look again just incase I missed something.
  #20405
Old Yesterday, 09:29 AM
chick
chick is offline
chick is starting off with a positive reputation.
Tried to back up on Saturday, truck would not move until I pulled forward a few feet. So yesterday pulled the calipers, and one piston on each side was totally fractured, I had to pry them off the rotors. So off to the parts store (1 hour each way) for calipers, pads and rotors. Got home, stated the install, one caliper was no good. The bleeder was obviously cross threaded, hack at the refurb shop should have seen this, but let it go anyway. So back to the parts shop, another 2 hours of driving, swap it out, and back home. Finally got all back together. This would explain why the mileage was down to about 12.5 mpg. I hope it goes back up now.
  #20406
Old Yesterday, 11:05 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is online now
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Originally Posted by Excurvelle View Post
How is the best way to bleed the system, I think mine has an air pocket.
I just drive mine until it's at full operating temperature and when I get to where I'm going to be for several hours I crack the cap SLOWLY to let the pressure off then tighten it back down and let it cool completely. Next time I drive it I do the same thing. I notice that the DEGAS bottle will change slightly (usually goes down a bit).
I do this twice a year because I change thermostats for summer and winter and it works well for me. Occasionally I'll see it burp a few bubbles, but not often.
  #20407
Old Yesterday, 11:42 AM
m54sam's Avatar
m54sam
m54sam is offline
m54sam is starting off with a positive reputation.
DTC P0673 just showed up this weekend...and just ordered from Amazon Glow Plug harnesses (right and left in the same kit) and will be starting there...following this thread https://www.ford-trucks.com/forums/1...dtc-p0673.html. From what I understand the harness tends to go first, but I can't help thinking maybe I change the glow plugs at the same time while I have it apart. Thoughts?
  #20408
Old Yesterday, 12:15 PM
Excurvelle's Avatar
Excurvelle
Been doing that but my "new" replacement Mishimoto thermostat still has wild swings. I may put the old thermostat back in and be done with it or buy a Motorcraft.
  #20409
Old Yesterday, 01:12 PM
Turd-250's Avatar
Turd-250
Turd-250 is offline
Turd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant futureTurd-250 has a brilliant future
i'd sure be inclined to at least pull out GP #3 and ohm it, see if its in spec. that's me tho!
  #20410
Old Yesterday, 02:49 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
You want an IH T-stat the Motorcraft nes don't last long.
This is what I put in my 2006.
  #20411
Old Yesterday, 04:25 PM
m54sam's Avatar
m54sam
m54sam is offline
Will do, thanks!
  #20412
Old Yesterday, 10:22 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is online now
KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.
Nothing to the truck....but I am searching for real estate near grapevine tx.
Any input greatly appreciated
  #20413
Old Yesterday, 10:47 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
I wanted to install my new EBP sensor and tube, however my father broke his ebrake on his motorhome, and ran into some landscape timbers. And he's supposed to go to myrtle beach in a month. I'm terrified, at his age he shouldn't be driving a 37' motorhome 800 miles. He suggested that I drive him and fly back.
  #20414
Old Today, 07:52 AM
Excurvelle's Avatar
Excurvelle
I feel your pain. My mid 80's parents are all the time driving to Maryland/Pennsylvania/Ohio from North Carolina. I hear the stories about how they ran off the road and got tired or cut somebody off but what can I do? I am glad they are driving a car not a MH.
Misky6.0
245
07-08-2018 07:34 PM
Usmc6.0
05-17-2017 04:16 PM
04Stroke363
1999 to 2016 Super Duty
03-09-2017 08:03 AM
Phillipspd
02-24-2017 10:05 PM
Mustangman68
04-12-2016 09:46 PM
Quick Reply: So what did you do to your 6.0L today?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
