1965 Ford F100 3 Speed column Shift transmission with overdrive
Bell housing is the same 3 M/T, 3 M/T with O/D & 4 speed:
1965/66 F100/250 352 2WD; 1966 F100 352 4WD; 1967 F100/250 2WD/4WD & F350 352; 1968/76 F100/250 2WD/4WD & F350 360/390.
C5AZ-6375-K .. Flywheel-Use with 11" clutch. (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1965/67 Galaxie/LTD 352; 1965/67 F100/350 352; 1968/76 F100/350 360.
C5AZ-6375-L .. Flywheel-Use with 11 1/2" clutch. (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle / Obsolete
1965/71 Passenger Car 390; 1968/76 F100/350 390.
Blue50F-1
08-20-2009 02:18 PM
Sanford Owner
04-11-2005 10:09 PM
