Felt like being rear ended
2010 f150 supercrew fx4
While driving down the highway yesterday at about 65mph I went to change lanes. As I was changing lanes I gave it a little gas. About half way through the lane change truck jerked like I had just been rear ended. I immediately checked my mirrors to see if I changed lanes in front of some body. No one was around. Truck still ran the same. Everything I'be read seems like similar thing happen to others at slower speed.
our parts truck here at work is a 2010 sc/6.5' bed 4x4 4.6/4spd. if your cruising on the highway around 55-65 or so and stomp on it, it will down shift from OD and SLAM into 2nd gear. I have mentioned about having it looked at before it either A: breaks or B: goes out of warranty but no one has seemed to care except me.
My old '96 GMC Savana did that when the valve body and associated parts failed which was a chronic issue with the 4L60. (It went through three transmissions and SEVEN reman valve bodies under warranty between 50k and 66k miles when I got rid of the thing). The shifting like you were being rear ended was a symptom. I did have an old '70 Hemi Cuda with a full manual B&M Torqueflite that shifted that way on purpose, all the time, but that was a different application behind a 12.5:1 Hemi with a crossram manifold.
Good luck; I hope this is just a temporary or software glitch for you Ford guys.
George
George
at one point I had a Built 700R4 with full manual valvebody and it had a hard shift and this is nothing like that was.
mearsglassworks
02-23-2010 04:49 PM
