78/79 RestoMod
#482
#483
#484
Went to the local Pick a Part today and scored big time!
I got a 3G alternator, not real sure about the specs on it I need to do some research but it is labeled "Built by Aurora", maybe someone here has some info on it?
It is nice to get the external regulator and associated wiring. Really cleaned up the bay. I also rerouted the engine and EFI harnesses low on the firewall and around back of the engine. I had the shop that made my brake lines make me a braided stainless steel external oil line, not taking any chances.
Also found a set of manual hubs, I had to use the Warns that came with my axle on the F250 when one of the caps went missing.
I will be cleaning these up and painting the ***** when I clean up the rotors.
Picked these up for $62, not too shabby.
Wiring looks pretty clean, eh Greg?
#487
#489
#492
This one tight engine! oil pressure is amazing and I love the way it just stops when it shuts down. Hopefully going to exhaust next weekend!!!
I also have a video of the break in, damn I relieved everything went well.
http://www.supermotors.net/registry/media/1047775
#495
Huge progress today with Greg's help, plan was to do a shake down run but that didn't happen.
The power steering pump isn't work, I am pretty sure I messed up the check valve when I reassembled it, I will draining it tonight and see what I did wrong.
Anyhow on to the fun.
Got the hood back on, needs some adjusting.
Got all of the mounts and suspension torqued down
got some fine tuning on the fuel mixture done
Got some other misc nuts and bolts stuff done
She was able to move under it's own power for the fist time in over 3 years!
She is a BIG girl lol
About 6" too tall to fit in the garage
