driveshaft support bearing
Want to pull the trigger on a new one. Really want the Timken one, but not sure what one to order...2wd xcab, if that helps...
1999 FORD F-250 SUPER DUTY Drive Shaft Center Support
You know what confuses me?...Ford wants $120 for the OEM bearing.
F81Z-4800-FA. MSRP $120.60.
The TIMKEN part (which I think is HB88107A Drive Shaft Center Support Bearing) is $25 delivered from AMAZON.
Why the crazy discrepancy?!?!?!
National Bearing also makes the part and has it listed with prices varying from$20-50$....Why the variation in prices? Is the quality going to vary that much?
Timken/Driveshaft Center Support (HB88107A) | AutoZone.com
Rock Auto says it does fit!
Who is correct?
Not to muddy up the water... But I thought there was 2 different size c.b. for our trucks. If I recall there is 2 different drive shaft O.D.'s . Is this true?? I had written down Spicer # 211499x and #211359x And I didn't write down with one was what but I made a note that bearing I.D. was 1.574
Hopefully later tonight I'll see if I can't answer my own question. Unless one of you know anything about there being 2 different sizes. Thanks !!
...and you need a 1 5/16" socket to get it off.
SleeprLegend
12-15-2010 04:22 PM
brigadoon
02-24-2010 04:50 AM
jbrittonjr
07-13-2009 08:53 AM
Fair 96
02-03-2005 09:22 AM
