Mustang II power rack replacement
My mechanic friend replaced the power rack and pinion on my 53 f-100. We didn't realize the original rack had a 4 inch extension from Fatman on it. We purchased and installed a new 4 inch extension on the new rack - but the wheels are still not aligned right. Are there differenct tie rods that are required to make this work? Any suggestions would be great.
well there are two different arrangements of the rack.. centered, and offset
on centered you need TWO extensions, or two elongated tierod ends
on offset you need ONE extension..
I have centered on both my trucks.. one has the extensions, (three different below)
Inner Tie Rod Extention Kit - Speedway Mustang II Manual Rack - Speedway Motors, America's Oldest Speed Shop
Mustang II, T-Bird Inner Tie Rod Extension - Speedway Motors, America's Oldest Speed Shop
Garage Sale - 2 Inch Tie Rod Extensions, Mustang II/T-Bird Power Rack - Speedway Motors, America's Oldest Speed Shop
and one has the longer tierod ends..
Mustang II Extended-Length Outer Tie Rod End - Speedway Motors, America's Oldest Speed Shop
sounds like you have the offset type rack if u have only one extension.
A centered rack will NOT work on an offset rack chassis (and vice versa)
Sam
Sam
Thanks sdetweil. Can you tell me how to identify\confirm that I have a centered or offset chassis? My mechanic called Fatman and they told him that the rack part number is correct for their mustang II. Apparently they never mentioned center vs offset options. Thanks again for all your help. If possible can my mechanic call you with a question (if not, I understand) - he is pulling his hair out on this one.
this is that thread, and a set of measurements I (and others) made
https://www.ford-trucks.com/forums/9...ml#post9147582
Sam
you don't have 25 posts on FTE yet, so you cannot send or receive private messages here, or send email thru here (prevents spam bots from abusing FTE)
Sam
Doc
05-18-2011 09:47 PM
Gary E
12-28-2006 09:27 PM
lbyblock
09-17-2002 12:22 PM
