Maryland Chapter Join Chapter, Leader: BPofMD
Steering shake
Old 03-09-2012, 10:58 PM
Blade79's Avatar
Blade79
Blade79 is offline
Steering shake
Hey guys I need some help. My wife has a 2001 Explorer 4 wheel drive. I replaced the brakes all around tonight. New rotors and pads front and back. Other than having to beat the living crap out of the rear rotors to get them off, everything went as normal. Got everything back together and cleaned up and pulled it out of the garage and when I turned the wheel to pull out of the driveway and the steering wheel shakes when I turn it. Happens when turning both ways. One I pulled out and got up to speed it was fine. It didn't happen again until I was at a stop and turned the wheel. One I pulled out it was fine. Could this be anything with the pwr steering? any help would be appericated.
Old 03-10-2012, 06:32 AM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Is this something you feel in the steering wheel, or the whole truck? Are you sitting still when it hapens, or moving? Does it do it in forwaed and reverse? What happens if you hold down on the brake when it acts up?
Old 03-10-2012, 09:59 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,097 Likes on 997 Posts
Sounds like the 4WD is still engaged.....
Old 03-10-2012, 12:45 PM
Blade79's Avatar
Blade79
Blade79 is offline
Thanks guy But I figured out that I some how got air in the pwr steering line. I popped the cap and cranked it all the way left, hold, then crank all the way right and hold. returned to center and filled up the pwr steering fluid. smooth as silk now. I guess where the fluid level was low and it was jacked up it was enough of an angle to get an air bubble. And yes It was only being felt in the steering wheel and not when moving only when sitting still. As soon as I would start to move it would smooth out.
Old 03-10-2012, 01:27 PM
dustybumpers
Glad you got it figured out.
Did you see that we have a multi state GTG in April? here's the link
https://www.ford-trucks.com/forums/1...bs-thread.html
stumprider69
1997 - 2003 F150
03-12-2012 10:05 PM
PSUJTF76
2004 - 2008 F150
08-14-2009 01:07 PM
ellmer
03-24-2005 11:11 PM
Quick Reply: Steering shake
