6 volt to 12 volt gauge wiring
Hello,
Started my 6 to 12 conversion. I plan on using the RUNTZ's for the fuel gauge and water temp, elimination the amp gauge and my oil pressure never did work and I have a below dash oil pressure gauge. Anyway I've removed the gauge cluster, removed the side section with ammmeter wiring. My gauges all have plates interconnection each gauge and then a wire running to the other side of each gauge. From waht I've read I need to remove the interconnecting plates and treat each gauge on its own. I do not see any polarity markings on the gauges, does any one know which is which on the gauges?
Thanks
Thanks
Glenn54
17
08-20-2017 02:29 PM
pineconeford
03-31-2013 10:20 AM
Chris123NT
02-25-2013 07:52 AM
