Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- Tire Modifications and Size Calculator
Overview of popular modifications to customize your truck
Tire Size/Axle Ratio....Confused...
Ok, so it is time for new tires again. Now towing near 10K so was thinking about the advantage of axle ratio affect of the two sizes difference. Thinking that larger tire would be less advantageous, but using a calculator online, it seems to tell me I actually get better ratio for towing with a larger tire?
I have the 3.73 ratio now.
New Tire Diameter: 32.8
Old Tire Diameter: 31.6
The calculator says the affective ratio is now 3.87 with the larger tire.
I know, not much difference, but did not think larger would go better for towing? What am I missing?
Looks like either the ratio calculator you used was working backwards or you may have entered old/new tire sizes inverted. When I plugged in your tire sizes to this calculator 4Lo.com :: Tire Size Change, New Gear Ratio Calculator and flipped the old/new sizes the result was your effective ratio of 3.87. When the sizes are entered correctly the effective ratio comes out as 3.59, which would be slightly worse for towing heavy.
I'm in the process of collecting all of the goodies to swap in a new set of axles with 4.88 gears on my 3.73 equiped EX. I'll be going from my stock 265/75R16's (31.5") to 305/70R18's (35") to wind up with an effective ratio of 4.39, that should make pulling the heavy ToyHauler much more fun.
I think an 85 series tire is a bit odd. You will find much more selection in the 75 series. You could go up in tire width, which also increases diameter. Going from, say, a 265 mm width to a 285 mm width (285/75-16) would increase the diameter from 31.7" to 32.8" (3.6% increase). I don't think it would increase mileage measurably. Effect on towing depends on diesel/gas and your towing speed as matched to aero drag.
CJay
03-16-2000 05:38 PM
